Help with installing rub rail
Charter Member #232
I assume you are talking about the stickes of plastic. If you are talking about the rolls you can put them in hot water and it will soften them up. If you are using the sticks then heat gun works.
Jon
Jon
Put your best foot forward!
how rigid is the rail? or should i ask ,who made it? you need to put a screw with a piece of thin wood dead center in the in the center of the hull/deck joint. use a heat gun and take your time ,your not dring hair and can burn or "brown" the rail (assuming it's white) and have a extra set of hands to pull.
you will have to put a "V" notch at the rear corners and use a product called "life seal" by boatlife, to fill any voids. stuff is great and works real easy. get it at west marine or any similar type store should have it in stock.
before making any v notch , take a extra piece and try. start at a 1/4" notch and bend around. another tip is to tape of the boat with a colored tape (blue) is easy to find and follow that as a guide otherwise you will have a "wavey" rubrail. and do not use pre exisiting holes to mount fill those with lifeseal or
3m and mark off on the boat the location of the old holes. good luck.
Location: Ocean Pines, Maryland. Wish I was at MANGOS in MIAMI!
1 Post
Ditto on what the other members said.........the first thing you need to do is heat up the entire rub rail sections. Gonna be tough due to where yuo live.
When I did my Midnight, I laid out the rolls of rub rail on black asphalt and I was amazed at how easy it was to work with after that.
It was nearly impossible to work with before.
Like one of the other members said, soak it in hot water, the hotter the better.
have fun
have fun
Thanks guys. The rub rail is in 20' "sticks" not rolls. It doesn't seem to stiff and it went around the bow okay but then I looked and there was a small "dimple" sticking downward. I removed it and heated it and the dimple went away so I should be able to re-use it on the sides/back. I'll try getting it warm and see if that helps.
