Go Back   Offshoreonly.com > General Discussion > General Boating Discussion
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 10-18-2007, 03:49 PM   #1
2000, HUSTLER 388 SLINGSHOT
12 Volt Air Conditioner
I would like to add A/C to my boat and would like to know if anyone has any experience with the DC Breeze by Glacier Bay. We overnight away from the docks many weekends and like the idea of 12 Volts! The unit would primarily be used for a short period to cool the cuddy down as I know extended run time would be limited due to battery life.
NEVERSATISFIED is offline   Reply With Quote
Old 10-18-2007, 03:59 PM   #2
Charter Member #928
Boatless for now
I bought the one that goes on the cooler. At night it might work ok but it won't do much with the afternoon heat. If you can install one go that route. There is in that that works with a separate battery but it's around a grand. It would be good if your boat is not rigged for shore power and doesn't have room for a generater.
wigginout is offline   Reply With Quote
Sponsored Links
Old 10-18-2007, 04:42 PM   #3
Forum Regulator
Sydwayz's Avatar
Active Thunder 37' & other Factory boats, 13' Mini Hawk
Touch base with crb76. He has been doing some research in this area. I think he has even found a company to lab the condenser and battery terminal connections for better performance.
Brian T.
Active Thunder Factory Rep.
Web: ActiveThunderBoats.com
Email: brian(a)activethunderboats.com
Sydwayz is offline   Reply With Quote
Old 10-18-2007, 04:50 PM   #4
S.O.B (single O/B) now
t500hps's Avatar
honda 2000 runs a 7,000 BTU unit without problems.....you can also power anythng else you need this way too.
t500hps is offline   Reply With Quote
Old 10-18-2007, 09:53 PM   #5
CRB76 any experience with any 12volt A/C?
Old 10-18-2007, 10:47 PM   #6
2000 29 fever with hp500
the one that goes in a cooler which is made by kooleraire works great in the cabin if you freeze 2 two liter bottles. work in the middle of the day and great at night and wont drain a battery completely down.
ebay number 330176795529
kickin32 is offline   Reply With Quote
Old 10-19-2007, 08:56 AM   #7
Diamond Member #001
C_Spray's Avatar
Formula 382 w/600 Innovations; 28 Batboat w/Ilmor 725 Indy
I went with a CabinMate 5000 (110 volt unit) and a 2000 watt inverter, but that was 10 years ago... Two Group 31 batteries would run it nonstop for almost 2 hours. Nice thing about it was that the inverter would automatically switch over to charge mode, and run the A/C on shore power when you plugged it in, so you get the best of both worlds.
C_Spray is online now   Reply With Quote
Old 10-19-2007, 09:13 AM   #8
Here you go:
http://www.marineair.com/contained/body.html
Their rotary compressors have very low startup currunt draw. I have a 110V unit and my genset doesn't even notice it start.
So I guess they packaged an AC unit and inverter together.
Side note: Always get a rotary control. The Digitals dont last.
Gary
rdoactive is offline   Reply With Quote
Old 10-19-2007, 09:50 AM   #9
AT Cult Member #3
R Addiction's Avatar
'99 Active Thunder Tantrum
Quote:
Ok has anyone ever seen CSprays boat? I rode on it last weekend, ended up staying over night on it ( Jello shots and Capt/Cokes) and this boat is done up. Upgraded to indy car specs right Chuck?
R Addiction is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
'99 Tahoe air conditioner satisfactionII Trucks, Trailers and Transportation 7 06-08-2007 12:13 PM
Air Conditioner question ??? HiPerf2000 General Boating Discussion 16 08-10-2005 08:37 AM
12 VOLT Cabin Air/Conditioner Fountain38 General Boating Discussion 10 06-29-2005 10:32 PM
Prime Air Conditioner farfrumwerken General Q & A 3 07-18-2004 01:04 PM
How to make a dockside air-conditioner? BAD-HABIT General Q & A 3 06-25-2004 09:10 PM
Search Engine Optimization by vBSEO 3.2.0
