Go Back   Offshoreonly.com > General Discussion > General Boating Discussion
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 10-29-2007, 03:28 PM   #1
Need advice
I was running the gas low in my motors with Sea Foam in the fuel for the end of the season. I ran out in my port motor about 3 miles from the dock and kept running on plane to the dock and pulled out. Is there anything special I need to do with that motor? (Triple 502 MPI stock motors in a 47 Fountain)
fountain 47 sc is offline   Reply With Quote
Old 10-29-2007, 04:13 PM   #2
Forum Regulator
Sydwayz's Avatar
Active Thunder 37' & other Factory boats, 13' Mini Hawk
You probably want to fog those motors before putting it away for the season. You will need to put a few more gallons of treated fuel in there, enough to do the winterization/fogging. (Be sure you know how to fog a fuel injected engine correctly, by filling the fuel/water separator 1/2 full of 2-stroke oil, NOT by spraying fogging oil down the throttle body.)
Be aware though, that running the last bit of fuel out of your tank sucked all the sediment and crap that is floating and suspended in your tank into the fuel filter and/or fuel water separator. It is advisable to change them out for safety's sake. I'd do this now on that motor that ran dry, and run the fresh 5 gallons or so of fuel through it while winterizing. If anything made it into/past them, I'd want to make sure that crap was not going to stay there for the winter to create more havoc.
Running a gasoline 4-stroke engine out of gas is not too terrible. Doing so with a 2-stoke is definitely not good. Doing so with a diesel is also not good, but mainly because they are so hard to start dry.
Brian T.
Active Thunder Factory Rep.
Web: ActiveThunderBoats.com
Email: brian(a)activethunderboats.com
Sydwayz is offline   Reply With Quote
Sponsored Links
Old 10-29-2007, 04:57 PM   #3
Thank you. I will take your advice. I may want to take it out a few more times this season if the weather is nice and I keep it in a heated building but it sounds well worth it to do the simple things you suggested to prevent any problems. I'll do it this week!
Old 10-29-2007, 06:27 PM   #4
TexomaPowerboater's Avatar
1990 28 Apache FOR SALE, 03 Sea Ray 240 sundeck
Quote:
Thats funny. I was trying to winterize my buddy's 25hp merc OB and he told me to run it out of gas with fuel stabilizer. It started running pretty bad at the end and I just shut it off. I figured since the fuel was also the lubricant (since its mixed with oil) then running it out of gas was not the best idea.
TexomaPowerboater is offline   Reply With Quote
Old 10-29-2007, 06:31 PM   #5
Charter Member #232
Audiofn's Avatar
1979 Formula 302
DEPENDS on the outboards. If they are oil injected then you are fine running them low. I don't like to leave gas in any of my motors for long times.
God is my Co-Pilot..... but I hit a mountain and had to eat him.
Audiofn is offline   Reply With Quote
Old 10-29-2007, 09:18 PM   #6
Forum Regulator
Sydwayz's Avatar
Quote:
It all depends on the layout of the oil injection system, depending on when the oil is injected into the fuel/cylinder. If you have a carbureted 2-stroke, chances are not much of the oil is going to make it to the cylinder when the reeds are 'open.' If you have a fuel injected and oil injected 2-stroke, you are in better shape, but I still don't recommend it.
Brian T.
Old 10-29-2007, 09:28 PM   #7
Just changed the filter, started it and it runs fine. Thanks for the advice. I may hold off on fogging them.
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Looking For Advice screamin_69 Prop Talk 9 04-18-2008 12:35 PM
Need advice please fountainfevr Fountain 12 06-13-2007 11:33 PM
Advice on a New 38 nolimits Fountain 48 10-08-2005 09:57 PM
Need Advice Please SLINGSHOT General Boating Discussion 15 05-16-2002 08:33 AM
Search Engine Optimization by vBSEO 3.2.0
