Keeping it Clean???
Old 10-30-2007, 07:38 PM
Default Keeping it Clean???
HEllo I am a new owner of a 2002 Scarab 33' AVS wich just got delivered in Ontario Canada. My problems is taking out stains from falling leaves.. Had it parked on the trailer for a few days and it stained the top of the boat. I tryed cleaning it but it leaves a stain where the leaves where sitting. Is there something I can use to take it out? Maybe the boat was not waxed and now that does not protect it? it seems to stain very easy. Anyone have any ideas??
Nuke800 is offline
Old 10-30-2007, 07:41 PM
Magic erasers or worse case use an oxidation remover with buffer and they should come out. Ablsolute worst case is wet sand.
baywatch is offline
Old 10-30-2007, 07:44 PM
seafordguy's Avatar
Believe it or not - even when ON/OFF won't get the stain out - letting it sit for a day or two in the sun will completely bleach it out.
On a related note - someone spilled some red wine on my seats and it sat over night - I was devastated, but low and behold, after a weekend or two of normal use and the resultant sun exposure - the stain is gone.
seafordguy is offline
Old 10-30-2007, 08:05 PM
Registered User
Oxy-Clean. Works wonders. You can also lay a rag on it and soak it with hydrogen peroxide.
Chris Sunkin is offline
Old 10-30-2007, 08:18 PM
Elite Marine's Avatar
As stated previously let it sit in the sun and use a mild compound. They will come out...don't fear!
Elite Marine is offline
Old 10-30-2007, 08:51 PM
SLOWOUTBOARD's Avatar
Try Tilex
SLOWOUTBOARD is offline
Old 10-30-2007, 10:49 PM
Received 1,826 Likes on 911 Posts
I've had the same thing happen before. Even worse was the leaves fell in a storm and were wet and sticking. I tried several things, most of which required a lot of work. Then I simply sprayed on some Clorox Clean Up on the stains. They disappeared within minutes. Wash normally after and rewax.
Griff is offline
Old 10-30-2007, 11:09 PM
Thank you for all the tips.. I will try this...
Nuke800 is offline
Old 10-30-2007, 11:32 PM
stecz20's Avatar
i know it sounds really bad.. put some bleach in a spray bottle and spray the deck, then wash right after.. then i would put a layer of wax on.. i had big stain problems around my house and i would do it quite a bit, but would also wash and spray wax right away.. never any problems, and the deck of my cig was as bright white as if it was new....
stecz20 is offline
Old 10-31-2007, 07:33 AM
OSO Moderator
BillR's Avatar
To all:
Do NOT use ON/OFF anywhere on your boat. It is really VERY bad for your gel coat.
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Quick Reply: Keeping it Clean???
