Wondering what boat builders are using all composite material. >
Old 11-21-2007, 06:30 PM
THEJOKER's Avatar
Originally Posted by Jigsaw89
Approximately how thick is a solid glass bottom on your 26' vs cored with balsa? If you don't mind explaining, what are the pros & cons of these two construction methods?
Thanks,
Dan
Sorry didn't read your thread correctly. Balsa is great just ask Skater. It's lighter than all glass or wood. For shear strength nothing is stronger. We're not all about super light weight though. Boats can get too light and that means flighty and a rougher ride and more hull failures. We build boats to run in the ocean where it's rough.
THEJOKER is offline
Old 11-21-2007, 07:36 PM
Jassman's Avatar
Originally Posted by THEJOKER
Just me personally but I wouldn't want a 100% wood free boat. We use a little wood and composites.. Always wood transoms (ask Will at Phantom) . No wood stringers though , all glass. Wood in the back side of the dash where the steering wheel mounts , bow hook and some other areas. When we core we use balsa ask (Skater) and sometimes a solid glass bottom (26). A little wood never hurts!
I agree totally...Nor-Tech uses wood in certain area's as well.
Jassman is offline
Old 11-21-2007, 07:41 PM
Forum Regulator
Sydwayz's Avatar
Received 1,193 Likes on 518 Posts
Originally Posted by 29scarab
I'm sure there are a lot of builders using composite today to stay away from rot. What is the cost difference of composite compared to marine grade plywood?
Who is using all composite and who isn't? I beleive that Active Thunder uses all composite, but who else out there does?
Just thought it might be an interesting subject: The pro's the con's if any.
All input is greatly appreciated.
Thanks,
Shawn
P.S. No pocorn and drink on this subject either!
Active Thunder does not use wood. True.
Sydwayz is offline
Old 11-21-2007, 09:38 PM
Charter Member #232
Audiofn's Avatar
One of the bigest reasons for the use of Balso is that it absorbs energy on compresion.
Put your best foot forward!
Audiofn is offline
Sportboats
09-24-2008 08:05 PM
littledcsrodshop
09-09-2005 02:52 PM
Formula Outlaw
01-13-2005 01:19 AM
ducati750
10-10-2003 11:21 PM
wayne
12-13-2002 06:11 PM
Quick Reply: Wondering what boat builders are using all composite material.
