prop shaft adaptor
i have a prop shaft 19spline but when i find a prop second hand to try on my boat its maby 25/26/spline how many splines are there or can i buy adaptors that will adapt to my 19 spline it would work out cheeper than getting a new shaft made everytime
cheers gerry |
There is an adapter available from Arneson for the longer shaft approx. 6" hub.
http://www.arneson-industries.com/pa...id=performance There is not one available for the short prop shaft, hub 4" approx.. If you have the small/ short shaft.The 19 spline tapered props are harder to come by. I am having the same problem. |
lucky enough i have the long hub 19 spline i need a prop something like a 17/16x24
