Vinyl graphics removal?
Old 02-07-2008, 09:16 AM
Default Vinyl graphics removal?
ANy thoughts how to get them off?
The graphics is 12 years old and it's like trying to peel off paint. Help.
Thx. P
PARADOX is offline
Old 02-07-2008, 09:19 AM
Registered User
Heat gun & soft plastic scraper. The motorcycle stores have a decal-removal product that works OK. Goof-off will also soften the glue.
Chris Sunkin is offline
Old 02-07-2008, 10:15 AM
Thunder1's Avatar
CS has the right idea!! In addition something that is inexpensive to aid the process is Naptha... You can get it at Home Depot or your local hardware store and it will help soften the adhesive and will not harm paint or gelcoat... It is about $14 a gallon and is a great chemical... Beware while using the heat gun, possibly only while the surface is warm... It's flamable... Hope this helps!!
Thunder1 is offline
Old 02-07-2008, 10:30 AM
Since you live in Fl. it would't hurt to park it in the direct sunshine a few hours before you start. Every little bit helps.
45SS is offline
Old 02-07-2008, 10:33 AM
if what chris said doesn't work because the decals have become to brittle you may have to resort to sanding them off.
VetteLT193 is offline
Old 02-07-2008, 10:36 AM
fund razor's Avatar
The only thing is though..... nothing works on lightning bolts. Those stay on there forever.
fund razor is offline
Old 02-07-2008, 10:44 AM
THanks.
It's not brittle yet. It's the silver waves etc. that's comng off, for re-paint.
PARADOX is offline
Old 02-07-2008, 12:22 PM
Racer
Racer
Wahoo ATV's Avatar
You can also use "Graffiti Remover" for home depot. It comes in a spray can. Obviously, dont let it sit over night on the boat. It took about 5 mins of soaking on mine and them they peeled right of with a plastic squeegee.
Wahoo ATV is offline
Old 02-07-2008, 12:29 PM
Back4More's Avatar
WD-40 gets the glue off after you peel.
Back4More is offline
Old 02-07-2008, 07:22 PM
Hot sun and goof off always worked for me............
Donzi Corleone is offline
Quick Reply: Vinyl graphics removal?
