I to did a lot of research on the Piratecomps, Best price best sound and I like the idea of everyone being able to talk without that shutdown sound you get with some of the other headsets,
Originally Posted by BOSSMAN
(Post 2463310)
What was the discount for OSO?
Originally Posted by ToMorrow44
(Post 2463961)
I have Comp Comms in my boat. A question for some of you out there, what style headset do you have and how do you keep them from coming off of your head at high speeds?
-Tom |
I have been talking to Comzilla and they make a chinstrap that will keep them from blowing off.
Originally Posted by johnlomant
(Post 2464431)
I have the pirate com xtreme series and love it great quality
What is the difference between the reg and the xtream? |
I have not had any problem with the Racing Communications headsets even being remotely loose and have run triple digits with them on.
I have a extra comp com and racing comm system left over from racing days.....standard headsets...anyone interested pm me with offer
Thanks |
I have sigtronics.
The sps-4sn: $275 http://www.sigtronics.com/air/spa_4s.html - It is the high noise environment one. It comes with two different panel plates. One for vertical mount and one for horizontal mount. It only requires 3 small holes to munt in a panel. The barrels (headset plugs) Are loose and need to be mounted to a mounting plate. I used the mounting plate/cover for a radio shack project box for $2 each. They are 1 x 1-1/2 black plastic with four mounting holes in the corners and chafered edges. You drill two holes in the center for the barrels and place them in the boat near the seats. Another nice thing is the music dims down when you talk. Micmuff from oregon Aero: $14 ea. http://www.oregonaero.com/p747576_2001.html - A must have for total silence. Av Comm AC200 headsets: $98 ea. http://www.mypilotstore.com/MyPilotStore/sep/1473 - These are great because they are all stainless and plastic construction. They work great but they will fall off your head at around 90mph in a boat with a low fairing and no wind deflectors. I use small goggles over the headset which holds them in place. total for 4 person was $731 + 30 for misc wire/supplies. System works great. At first I had a little bit of wind noise at speeds above 80. Not bad, but I wanted it silent so I ordered the micmuffs. The ones that come with the headsets don't work as good. Install is a little easier than a stereo system. Expect around 2-4 hours depending on skill level. |
http://www.oregonaero.com/p747576_2001.html - A must have for total silence. Which ones did you order, do you have a P/N |
I have tiger performance, set up for 6, ipod connected, I have push to talk, works great but expensive as hell.
http://www.tigerperformance.com/ |
