If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. #11
    Registered User
    My Boats:
    Beat up ole Sleekcraft
    Join Date
    Feb 2008
    West edge of the Pacific
    Bandit my 2 cents
    Joe its like when they brought out the QSB 480hp they moved the HP peak further up on the rpm band so they could keep the same gearbox as the QSB 420hp without the gear breaking. Its torque that breaks stuff not horsepower.
  2. #12
    Join Date
    Mar 2008
    torque vs horsepower...
    Think of it this way,
    Say your turning an engine over with a breaker bar and socket on the harmonic balancer bolt. Torque is how much force you are applying to the handle of the breaker bar - if you use a longer breaker bar, you can apply more force, apply too much force, the bolt breaks of and you may put the breaker bar through the garage door (don't ask me how I know this).
    Horsepower would be the work you could exert in a given amount of time to move the boat forward. Torque is force in the radial direction against resistance (no resistance = no torque; think about the same breaker bar and socket turning the same engine over with the plugs removed - take a lot less force), horsepower is force times speed divided by time (or torque times horsepower).
    Changing gear ratios is like changing the length of the breaker bar - higher gear (ie going from 1.98:1 to 1.5:1), less mechanical advantage is like using a shorter breaker bar.
    What will break the gears in the drive is torque - high torque engine at low speed / rpm (the speed range where there is the most resistance). More cam actually helps in this regard because it kills low end torque (can also make the boat a major DOG out of the hole), as can a ventilated prop (let's the prop slip and reduces the torque the drive feels) and especially a light hand out of the hole. As for reversion (sucking water up into the engine) it gets very complicated when you get close to the line. The only way to really know, is to set it up, run it (in the water), let it idle for a while. if it's pretty bad, you can usually hear it load up at low idle, then it will clear up and run fine at a little higher rpm "idle". There's really no substitute for running at your low set idle for a little while and then pulling a manifold to see if there's water at the head...
    Hope this helps...
  3. #13
    Registered TYPHOON's Avatar
    My Boats:
    Join Date
    Feb 2001
    Edison NJ USA
    So what would be a good cam for this motor? And yes it has aluminum heads.
Similar Threads
  1. The 272 debate: small block or big block?
    By handfulz28 in forum Formula
    Last Post: 10-15-2006, 02:25 PM
  2. Small Block to Big Block??????
    By DKerns in forum General Q & A
    Last Post: 09-05-2006, 01:40 PM
  3. New 27 With A Small Block
    By z.zuperboat in forum Activator
    Last Post: 03-13-2006, 01:11 PM
  4. Small block and Big block kits
    By chriscraft240 in forum General Q & A
    Last Post: 08-28-2003, 01:17 PM
  5. Big block vs small block
    By Da Patriot in forum General Q & A
    Last Post: 11-24-2002, 08:27 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
