Are cats really that dangerous? >
Old 05-12-2008, 03:11 PM
  #181
SORE MEMBER
Wobble's Avatar
Originally Posted by T2x
They are the fastest turning racing vehicles....of any kind....on the planet.
T2x
I thought Formula 1 race cars laid claim to that title on the ground and the unlimited class Reno air racers in the air
Wobble is offline
Old 05-12-2008, 04:25 PM
  #182
T2x
Allergic to Nonsense
T2x's Avatar
Nope and nope........
You have to see a Champ boat turn to believe it.........I speak from first hand racing experience in the cockpit.......the G's are indescribable.
From the Champ Boat website.........
"High Speed Turns and Pure Excitement
High speeds, sharp turns and constant action
• Due to the shape of their tunnel hulls, Champ Boats are able to turn almost instantaneously
Incurring more "G" forces than any other racing machine on earth
• Enables them to race close to river banks and lake shores
• Provides excellent spectator viewing
Champ Class (F1)
• Nearly identical to the Formula 1 machines raced internationally on the UIM circuit
• Champ Boats are 17 feet long and weigh just 1,150 pounds with driver
• 380-horsepower engines enable them to reach speeds of 140 miles per hour "
T2x
T2x is offline
Old 05-12-2008, 04:43 PM
  #183
Airpacker's Avatar
Its freaky how hard those boats turn. Real freaky.
Airpacker is offline
Old 05-12-2008, 04:46 PM
  #184
T2x
T2x's Avatar
It makes you question what you're seeing with your own eyes...... blast into a 25' diameter 2 pin turn at 125 +... drop the nose and literally 1 second later..the boat is going in the opposite direction at over 100........
T2x
T2x is offline
Old 05-12-2008, 04:52 PM
  #185
PhantomChaos's Avatar
I presume that means that you have no factual counter point to my post, but you felt that you had to say something contrary nonetheless???
T2x
You are quite correct SIR!
PhantomChaos is offline
Old 05-12-2008, 06:53 PM
  #186
Question for T2X: How does the placement of the prop (i.e. single engine - center vs twin engine) affect the speed, efficiency, and rough water ability on a cat? Is a single engine cat more safe and/or stable than a same size twin?
TexomaPowerboater is offline
Old 05-12-2008, 07:07 PM
  #187
Comanche3Six's Avatar
I'm sure TX2 and Thor Heyerdahl ran into a similar question when they constructed Kon Tiki.
Comanche3Six is offline
Old 05-13-2008, 07:12 AM
  #188
T2x
T2x's Avatar
no........... for many reasons:
1. A single engine cat installation fills the tunnel exit adding compression and disturbing natural airflow. This engine placement will also tend to "trip" the hull upon re-entry after going airborne, perhaps increasing the tendency of the craft to stuff. The lone partial exception to this rule may be the above mentioned Champ boats which have such streamlined lower units and small propellers (see my avatar and prop pix below) that there is not as much disturbance or drag..... but there is still more than a dual application would create.
2. Twin engines allow for counter rotation and, if you spin them out, following the laws of nature and physics as God intended, you will achieve neutral torque and balance from the prop rotation.
3. In twin engine installations the sponsons protect the center section or upper drive components from random blasts of water at speed thereby adding durability to the drives. (when we raced triple outboard cats the center engine durability was always lower than the outboard mounted motors). Again you also reduce drag since most, if not all, of the gearcases' frontal area is "hidden" by the sponsons.
Of course these are just my humble opinions, based on decades of testing and development, rather than the "facts" that are readily available at Poker Run Cocktail parties and in West Coast Cat ads........... or from "State of the Art" Apache fans......
T2x
T2x is offline
Old 05-13-2008, 07:19 AM
  #189
T2x
T2x's Avatar
Comanche3Dollar:
You took the words right out of Thor's mouth.
Tee TWO EXX
T2x is offline
Old 05-13-2008, 08:14 AM
  #190
You're pretty funny for an OLD guy
Old guys usually know the best stories and jokes...
Now has anyone trying skating with using a single leg or using both ?
Which way is more stable turns better handles better and is faster ?
The answer is not a Fountain (with XXX monthly paments...).
MikeyFIN is offline
Quick Reply: Are cats really that dangerous?
