If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 50
  1. #31
    My Boats:
    1998 Baja 252 Boss
    Join Date
    May 2007
    Fort Myers,FL
    Quote Originally Posted by 88Fount33 View Post
    Yes and No,
    Yes, that is me with red hull and big Yellow Bimini (wife has sun issues and needs to stay out of the direct sun as much as possible, so the top covers the sun pad.
    I see you regularly too. We were anchored on the back side of Sanibel not far from you a few weeks ago. I'll come say hi next time.
  2. #32
    Registered User
    Join Date
    Oct 2003
  3. #33
    Registered fabricator's Avatar
    My Boats:
    A 13' Whaler with a 50 horse. Does that count?
    Join Date
    Jun 2005
    Cape Coral
    Quote Originally Posted by Chris Sunkin View Post
    Thanks for posting that Chris, I was just looking for a copy to put up myself.
  4. #34
    Registered User
    Join Date
    Oct 2003
    I'll have to dig thru the archives to find my Manatee Cookbook.
  5. #35
    Registered User
    Join Date
    Oct 2003
    Bon Apetit!
    ...and remember, catch & release is for pu$$ies.
    Manatee Recipes
    Manatee meat has a mild taste and readily adapts to recipes for beef. Choice cuts of meat, primarily the tail and peduncle, can be used in any recipe. The body and flipper meat, with just a little extra preparation and special recipes, can be just as tasty. I recommend cubing the less-tender cuts for extra tenderness or pounding steaks with a meat mallet.
    Regardless of what cut of manatee meat you are using, all fat and sinew must be removed before freezing or preparing. Even the yellowish fat between the layers should be removed. When using flipper or body meat, we recommend removing the white tendons and vessels as well.
    Manatee meat has been successfully frozen for over a year. This was done by removing all fat, wrapping well in cellophane and then again in freezer paper. Manatee meat can be tenderized in several different ways. Some restaurants run each piece of meat through a cubing machine. Other restauranteurs recommend pounding each peice of manatee with a meat mallet until thin, usually about one inch. All restaurants recommend cutting manatee meat across the grain for a more tender piece of meat.
    Body and flipper meat cuts are excellent choices for burgers, casseroles, ground meat, soups and stews. Peduncle and tail meat work well for roasts, steaks and barbecue.
    Regardless of which cut of meat you use, you will find manatee to be a very delicious and versatile meat. It is also low in fat, making it a great item for the calorie conscious person.
    Meat cut types
    Tail - cut across the base of the tail just below abdomen
    Flipper - sever the joints where flippers attach to body
    Peduncle - meat from peduncle muscles
    Torso - remaining meat from the back and ribs
    Appearance of meat cuts
    Tail - light pink to white with internal bands of hard white fat that appear circular in cross sections and run lengthwise near the tailbone
    Flipper - darker in color with small fat deposits along tendons
    Torso - similar to meat from tail but without fat bands
    Manatee Balls
    1 lb chopped manatee meat
    1 egg
    1 Tbsp finely chopped onions
    2 Tbsps. finely chopped celery
    1 Tbsp finely chopped parsley
    2 Tbsps finely chopped shallots
    2 Tbsps lemon pepper
    1/2 Tsp salt
    1/4 cup breadcrumbs
    1 cup cooking oil Flour to dredge
    Combine all ingredients, form into 1-inch balls. Allow to set for one hour. Dredge with flour and fry until brown. Serve hot.
    Baked Manatee
    6 manatee steaks
    lemon juice
    lemon slices
    garlic powder
    chopped parsley
    salt and pepper to taste
    Arrange manatee steaks in an ovenware dish large enough to place in a single layer, sprinkle with salt, pepper and garlic. Squeeze lemon juice over steaks. Cut a generous amount of butter into squares and place over the steaks. Arrange lemon slices over the steaks and then sprinkle generously with parsley. Bake in a 375 F oven until steaks are cooked. Serve with french bread.
    Grilled Manatee
    2 lbs manatee steaks
    1 Tbs. onion powder
    1 Tbs. garlic salt
    1 Tsp. butter for each steak
    Season steaks with onion and garlic. Place in an aluminum pan ( or wrap and seal in aluminum foil ) on grill. Dot each steak with butter. Turn over half way through cooking. Cook over medium grill for 15 to 20 mins.
    5 lbs manatee meat, ground
    2 onions minced
    3 potatos diced small
    3 bread slices diced small
    Season with salt, pepper and garlic powder Mix all ingredients and form into patties. Pan fry until golden brown.
    Manatee Broulettes
    2 lbs manatee
    2 egg yolks
    1/2 bell pepper oil
    2 stalks celery
    3 sllices of bread
    2 onions
    1 cup water
    Grind together with the manatee, onions, celery, and bell pepper. Soak bread in milk and press out. Add to ground mixture. Add egg yolks and season to taste. Spoon into hot oil and brown. Remove and in another pot add the water and bring to a boil. Put in the broulettes in the water and steam on low heat for 35 minutes with a cover on.
    Beer Fried manatee
    1 lb manatee
    Trim meat and cut into finger sized pieces. Soak pieces in beer overnight. Drain. Deep fat fry until golden brown.
    Manatee Spaghetti
    3 lbs manatee meat
    3-6 oz cans of tomato paste
    4 Tsps salt
    1 cup minced bell pepper
    3/4 cup chopped parsley
    2 cups minced onion
    1/2 cup worchestershire sauce
    1 lb mushroom stems and pieces
    3 cans (2 lbs, 3 oz each) tomatoes
    4 Tsps oregano
    3 cloves minced garlic
    2 Tbsps sweet basil
    1/2 lb sliced bacon, diced
    1-1/2 cups water
    1/4 tsp tabasco
    In a 4-6 quart pot, fry the bacon until crisp. Remove the bacon and all but 3 tbsp bacon grease. Add manatee meat which has been cut into 1 inch cubes and brown. (If using smoked manatee meat, omit this stage) Remove meat when brown and set aside. Sauté onions, drained mushrooms, bell pepper and garlic for 10 minutes. Stir in the tomatoes, tomato paste, water, worcestershire sauce, parsley, basil, oregano, salt and tabasco. Bring to a boil, reduce heat and simmer, uncovered, stirring occasionally, for 3 hours or longer. Add reserved manatee meat and simmer until meat is tender. Serve over spaghetti with parmesan cheese. Sauce yield is approximately 5 quarts.
    Manatee and Scallops
    4 manatee steaks - 1 inch thick
    1 egg
    1 cup milk
    1/2 cup butter
    Trim all fat from steaks. Cut and pound steaks until 1" thin. Beat egg and add milk. Dip each piece into egg mixture. In a skillet, heat butter. Saute steaks on each side 2 to 4 minutes. Serve 'scallop sauce' over manatee steaks.
    Soup Du Manatee
    2 lbs manatee meat, cubed
    2 tbsps oil
    1 cup roux
    1 cup onion, chopped
    1 cup celery, chopped
    2/3 cup bell pepper, chopped
    1 lb can whole tomatoes in juice
    1 lemon sliced across
    1 tbsp salt
    1 tsp garlic powder
    1 tsp red pepper
    1 tsp black pepper
    2- inch cut basil sprigs
    2 quarts water
    4 tbsps parsley
    Heat oil. Add roux, tomatoes and juice, onion, celery, bell peppers, lemon, seasonings and herbs. Stir well. Add water. Bring to a boil. Cover and simmer 2-1/2 hours or until meat is tender. Add parsley and simmer a few minutes more. Add dry sherry if desired when serving.
  6. #36
    My Boats:
    Join Date
    Jun 2005
    Cape Coral
    Good stuff, Chris!
    A friend of mine has a poster showing a manatee drawn up with all of the various cuts, just like beef. Got one of those?
  7. #37
    My Boats:
    Join Date
    Jun 2005
    Cape Coral
    Quote Originally Posted by Mike 35 Fountain View Post
    My house is on Lake Finnisterre and I go out at Tarpon Point. I'm about 15-18 mins to river.
    I had a house on the canal just south of the lake some years ago..... the builder of my house grew up here, he told me in the early years they would water ski up the canal, ski around the lake, and the ski back down to the river. Think we could get away with that NOW?????
  8. #38
    My Boats:
    27 monza, eggbeaters, no seats
    Join Date
    Nov 2006
    key west,fl
    I thougth ped uncle was the creepy relative you did not allow near the kids
  9. #39
    Join Date
    Jan 2001
    Cape Coral, FL / Toms River N.J.
    I used to ski in the lake also, thats when there were only
    about 7-8 houses. I've had the cops at my house a few times
    for running jet-skis and tubing with sea-doo boat. They also visited me for winding up the Fountain as I entered the lake,
    did one lap and then to my dock. Met the policeman 5 mins.
    later. It's OK though , I'm pretty sure I hold the record for
    the fastest lap on the lake.
  10. #40
    Registered User
    Join Date
    Oct 2003
    Quote Originally Posted by fabricator View Post
    Good stuff, Chris!
    Of course!
    A* - top of neck, cube or use mallet
    B* - neck meat, cube or use mallet
    C - back, tender
    D - body meat
    E - peduncle, very tender
    F - tailmeat, very tender
    G* flipper meat, must cube or use mallet
    * less tender cuts
Similar Threads
  1. Cape Coral?
    By jmackin in forum Ft Myers Offshore
    Last Post: 05-25-2007, 03:49 PM
  2. Here we go. Cape Coral FL
    By salesmanship in forum General Boating Discussion
    Last Post: 01-05-2007, 10:47 PM
  3. Cape Coral, FL HELP PLEASE!
    By Shane in forum General Boating Discussion
    Last Post: 10-29-2005, 07:00 PM
  4. Anything going on in Cape Coral?
    By bob in forum General Boating Discussion
    Last Post: 12-04-2004, 09:56 AM
  5. Boating and living in Cape Coral FL
    By KNOT-RIGHT in forum General Boating Discussion
    Last Post: 01-08-2004, 07:51 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
