If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Results 1 to 4 of 4
  1. #1
    My Boats:
    1994 Fountain Fever 27'
    Join Date
    May 2008
    Summerville, SC
    Another new guy question...
    What kind of maintenance do drives need? Also, how often does it need to be done?
  2. #2
    Platinum Member Platinum Member seafordguy's Avatar
    My Boats:
    Cigarette - Cafe Racer
    Join Date
    Jun 2006
    Seaford, VA
    Most guys on here pull the drives once a year to make sure seals, u-joints, and splines are functioning "properly".
    I change my drive lube once a year or every 50 hours - last year coincidentally I put about 50 hours on it. I would probably change it more often but I RARELY run the boat more than about 3500 RPM and the majority of my 50 hours are spent idling.
    General maintenance includes the greasing of the spline and U-joints, and the changing of the gear lube.
    Regardless of whether you are handy or not - you can do it yourself.
    I have bravos. Judging from the boats you seem to be looking at you should either have Bravo's or TRS drives....
  3. #3
    Registered User
    Join Date
    Oct 2003
    They should be opened up, re-sealed and re-shimmed on an interval basis. It cost a few bucks but alot less than buying Mercruiser parts- especially NLA parts. Proper clearances will keep them alive for a long time.
    Proper use is one of the keys here. If you want to do dragrace starts, buy a Sanger V-drive flatbottom. A TRS or Bravo on a heavy boat isn't going to hold up to hammer-down holeshots. Jumping is hard too. Mostly it's throttle mistakes on re-entry. landing flat/throttles closed puts a tremendous strain on the drive, as does winging them.
  4. #4
    Gold Member Gold Member Iggy's Avatar
    My Boats:
    '88 Formula F-206 LS
    Join Date
    Jan 2001
    Kissimmee, Florida
    It all depnds on how you run the boat.
    The harder you push it the more maintenence it requires.
    I don't run mine very hard. And I only have a 350 Mercruiser engine.
    I change my drive fluid once a year. But check the fluid level and condition (looking for water and metal debris) several times throughout the season.
    Pull the drive off and grease the coupler and input shaft splines yearly.
    Pull the prop off and grease the splines yearly.
    All grease fittings on the transom and gimbal assemblies get greased three to four times a season.
    I check the drive shaft and shift cable bellows prior to launching it every time. I also store the boat with the drive lowered to take the strain off the two bellows.
    Since my water pump impellor is inside the Alpha drive it only gets changed once a year. Drive has to disassembled to gain access.
Similar Threads
  1. another new guy
    By mull in forum Fountain
    Last Post: 02-13-2008, 08:36 AM
  2. New Guy Here
    By adam4by4 in forum Chris Craft
    Last Post: 09-11-2007, 04:32 PM
  3. question from a nordic guy
    By sandcraft in forum Fountain
    Last Post: 08-06-2007, 07:32 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
