If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Page 6 of 6 FirstFirst ... 456
Results 51 to 55 of 55
  1. #51
    My Boats:
    tel # 1-613-342-3783
    Join Date
    Jun 2008
    Brockville, Ontario, Canada.
    Hi Jeff and everyone.
    My first tiime here.
    I'd like to introduce myself, my name is Frank and I am the electronics/tuner at Hewitt's Marine Performance.
    I'd like to thank,Jeff for the opportunity to work on his engine, Dustin at whipple for help relating to the whipple setup, and to Bob at mefiburn for the software.
    I am here to try to help elaborate, explain a few points and hopefully, contribute to this board, which ultimately leads to more enjoyable boating!!!
    The purpose is to try to increase the level and depth of understanding of these engines.
    I apoligize ahead of time as this might be a bit long winded, as I will try to sum things up in one posting.
    Relating to the peak HP/TQ numbers, it seems that the whipple kits quoted HP/TQ numbers are pretty close. What I mean by that is I believe they are arrived at using a superflow engine dyno or a similar setup. Paul, who owns Hewitts Marine Performance has said for years and years that his dyno numbers are always low as compared to a superflow. The dyno pull tends to be very fast and short on typical engine dyno's and the fairly rapid ramping/acceleration of the engine creates a 6% buildup of kinetic energy on the dyno and therefore makes the HP/TQ numbers larger by 6%. Paul's Stuska water brake engine dyno can make a slow run and hold the engine at a steady rpm to get the least amount of kinetic energy and therefore a more steady and clearerTQ/HP number.
    Even this year, we have had numerous people comment that Paul's numbers are not as high as "so and so", yet they lead races, continously outperform and win.
    The fact that I had to throw so much more fuel at the engine, above the fuel maps that the engine came with, and it was running rich to boot, especially , holds a good testament to how much better Paul made the Dart heads flow from as cast. AIRFLOW makes HP. Since this is a supercharger, and therfore a fixed displacment/rpm of air volume, unlike turbo's, the airflow from the supercharger will not increase because of the engine RPM limit. BUT, what this does show is that a high quality engine build, properly done will make the same or more TQ/HP at a lower boost......since the engine consumes more air than before, the boost level has to be lower, the engine is simply more efficient now and therfore less restrictive. A natural and inherent by-product of less boost is less heat and more engine life.
    We did all the work, knowing that we were not going to go to a bigger supercharger pulley to bring the boost level back up to the stock whipple kit. The engine will obviously make more power at 6.5-7 psi than at 5 psi.
    The HP/TQ numbers of the dyno graph are SAE corrected and are acquired at the start and during the course of the day. SAE corrected, meaning to air temperature, humidity and barometric pressure.
    Jeff's 502 BBC reaches ~138 Kpa or 5.3 PSI of boost from 3000 RPM to 5800 RPM.
    If the 6% kinetic buildup/increase is placed on the720HP/753 ft-lbs numbers they become 763 HP/ 798 TQ....if a bigger lower pulley was used and brought the boost back up to 6.5 psi, the engine should produce numbers in the 780HP/ 815TQ range on Paul's dyno and 825 HP/ 863 TQ range on the typical superflow dyno......
    This engine does use and was tuned using 91 octane pump gas.
    Well, thats about it, hope this helps.
  2. #52
    Geronimo36 Gold Member Panther's Avatar
    My Boats:
    36' Apache Warrior
    Join Date
    Sep 2002
    Elkton, MD
    Thanks for the info.
    What's interesting is my engines always showed slightly more peak HP/TQ on steady state pulls than full pulls.
  3. #53
    Registered Canada Jeff's Avatar
    My Boats:
    Sunsation and Apache
    Join Date
    Dec 2003
    Ottawa, Ontario,Canada baby!
    Thank you for posting Frank, and welcome to the site.
    This engine build has educated me big time about supercharged engines. I feel ' 100% piece of mind ' with this engine.
    I still have to water test her, but once I do, I'll get you out on her to plug your lapp top in and make sure you like what you see.
    Thanx for posting, and again, welcome to the site !
  4. #54
    My Boats:
    Join Date
    Jun 2008
    Yep, we'll get together, when everything is sorted and the boat is in the water, then we can hone in on the behavior of the flow of water through the system, and therefore, operating temperatures, in real time and we can then see what we have , and make adjustments, if need be.
Similar Threads
  1. My HP 500 EFI Whipple motor made 903 ft/TQ and 839 HP
    By Strip Poker 388 in forum General Boating Discussion
    Last Post: 09-28-2013, 04:39 PM
  2. 600 = 720 ???
    By Superbabi in forum Superboat
    Last Post: 01-29-2006, 03:59 PM
  3. 150 ci ... 720 hp
    By stevesxm in forum General Q & A
    Last Post: 01-03-2006, 09:36 PM
  4. ZZ 575 /720 hp
    Last Post: 11-29-2004, 03:30 PM
  5. 720 hp gm big blocks
    By Al Oakley in forum General Q & A
    Last Post: 09-08-2003, 09:15 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
