More power, use less gas on Methanol injection
[QUOTE=Brad Zastrow;2610581]It was a custom setup for my engine.
In 106 miles on Lake Michigan the boat used less than 5 gals.
Wheres the pics ?????????????????
In 106 miles on Lake Michigan the boat used less than 5 gals. ???? were you under 8 lbs of B@@st for most of the run ??? the ICE INJ kit burns 18 gallons per hour when the selenoids open & lites are glowin
No pics but here is the video. http://www.youtube.com/watch?v=tpOCaGYyrOs Winthrop Harbor to Chicago and back north to Racine and back to Winthrop in about 60 minutes driving time. We did stop for a water break in Racine.
I cruise at 100-120 mph at 3 pounds of boost 4500 rpm at 2/3 throttle. Saves the engine that way. If I am at 8 pounds of boost or more I am going quite fast and not sure where I could stay in the throttle that long or even want to. I did use a fair amount at the Poker Run because of working the sticks in the water condtions.
Michael1 you are correct.
http://en.wikipedia.org/wiki/Octane_rating
[QUOTE=Brad Zastrow;2610785]No pics but here is the video. http://www.youtube.com/watch?v=tpOCaGYyrOs
Thats damn good BIG Daddy , what gear in those drives 1.24 or 1.35 ???? Sounds awesome you should ROCK the shootout this year ..what did ya run last year at shooters ?? thnx in advance
C@@l Vid BIG Daddy but i thought maybe you had pics of your install from ICE INJ @ rudy ......
ITS A SKATER NATION !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!
Brad,as far as running "windshield washer fluid" in your exspensive motor,I will re-state what I said again in case someone misunderstood this,A local supplier (super-flite oil co) sells 55 gallon drums of methanol alcohol,it contains no water,dye,soap etc, just typical industrial methanol alchohol. It's mainly used to mix windshield washer fluid to keep it from freezing but can be used for whatever you would use methanol alchohol for,the local drag and circle track guys have bought it this way for years for their motors,its no better or worse then what your getting because its the same stuff,Smitty
I sure wish someone would have told me 16 pistons ago.
Rudy @ Iceinjections is a first class act.He will supply my pistons after metanol kit is installed.
Just kidding Glen!!
Bill ya need to change your name to something esle no more running hot skater brother.
Just kidding Glen!!
Thanks Bill you had me at Loto also!!!
Brad your testing and reporting the great gains is the reason this site is still here. Now I cant wait I have my Christmas wish!! Sorry Aris I wont need another 8.
Smitty is super-flite in Mich , or ILL ?????? If you know could sure use a half dozen drums of it ... Don't know about Brads 5 gallonsfor 106 miles but we blew thru 55 gallons on a few test & tune runs and the KY poker run and we're out
This is cause.....Gasoline is for washing parts.
Gasoline is semi crap fuel.
In racing the only reason anybody uses gasoline is because the rules mandate it.
I believe (don't quote me) methanol is the equivalent of 116 octane gasoline.
And it cools your pistons, valves, etc. Although, it is corrosive to certain metals.
