Go Back   Offshoreonly.com > General Discussion > General Boating Discussion
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 02-27-2002, 07:49 PM   #11
RLW
I like to refer to it as "Chine Walk".
RLW is offline   Reply With Quote
Old 02-27-2002, 07:52 PM   #12
Enjoy the show
Ron P's Avatar
Sound a little like Harley and AMF.
Ron P is offline   Reply With Quote
Sponsored Links
Old 02-27-2002, 08:25 PM   #13
ScreaminDemon
OK, here's the story. In about 1984/1985 Stepp was having some financial problems and sold the rights to several Velocity products to Regal, (22, 26, 30) and they were marketed as the Regal Velocity...good try, wrong manufacturer. Stepp then made a few deck changes and called his stuff Thoroughbreds (on certain models). After the licensing expired, he changed everything back over to Velocity and kept the newer deck designs (too bad). Velocity's are laid up light, but that is not why they have problems, light can be right, but takes expensive materials and experienced technicians, which he has NEVER had. They are a handful to drive to the INexperienced drivers, good drivers can drive the boat without CHINE-WALK at any speeds...his 30 footer was a perfect example...the FIRST vee hull to do 100MPH! I have been in the 33 at over 90 MPH and the boat is stable as can be...BUT, you gotta drive it, and that isn't easy without experience!
Old 02-27-2002, 08:55 PM   #14
cuda's Avatar
The price sounds a bit high to me. Last weekend I checked out a new 2001 Velocity 260. They wanted 47K for it. As far as the cabin height, I sat in it and a Donzi 26 zx, and the Velocity had more headroom.
cuda is offline   Reply With Quote
Old 02-27-2002, 11:05 PM   #15
Evil Twin
Last Year at the Chicago Boat Show I asked the reps from Velocity if you could install a Roots type blower in the boat. Thier comment back was Yes and No. To install a Root's blower in the boat they suggested that you had to cut a "U" in the panel (structural cross stringer that the gas tank is behind) below the bottom of the rrear seat to accomodate the cut down to 2" blower pulley's. Then the said that you had too cap the "U" shaped cutout with steel to hopefully keep structiual integrity. He also noted that it would void the warrenty and did not recomend it. There is not enough room to use cut down blower pullys from my eyeballing of a 28'.
Just what I was told, Is anyone running a blower on a 26 or 28er???
Old 02-28-2002, 04:09 AM   #16
OSO Content Provider
Commercial Member
SHARKEY-IMAGES's Avatar
WHAT YEAR WHO BUILT WHAT?
I'm repairing a 1989 but can someone tell me who was building the boats that year??? The outer portion of the main stringers were exposed at each bulkhead therefore allowing water to get into it and rot...It appears the stringers and bulkheads were all built as one unit prior to putting them into the boat, leaving the outside of the stringers without one continueous layer of glass.
www.Sharkey-Images.com/
Digital Photography one BYTE at a time !
SHARKEY-IMAGES is offline   Reply With Quote
Old 02-28-2002, 04:22 AM   #17
Commercial Member
Another angle:
Old 02-28-2002, 02:58 PM   #18
Revelocity's Avatar
Velocity 390 and Velocity 220
I think that 33K for the '93 28' with HP465 is a fair price provided the boat is in sound condition. Frankly I've never seen a '90's vintage boat priced that low with that kind of power.
Tim - In 1989 Regal was producing the boats but I'm sure you can verify from the Hull ID - V for Velocity and presumably R for Regal.
Evil Twin - There are plenty of 28's with roots blowers and sufficient room in the engine compartment on the one's that I've seen. Even the new, cut down VR1 featured a Merc 575 at the Miami Show this year! The 260 (24' boat) may have a problem with bulkhead clearances - "Velocity260" can better comment here. The dealer's reference to warranty issue probably had more to do with the hull being fully warranted for factory power only then cutting in a clearance space.
Not sure on the older 28's but for the last 7 years or so they have had 5'4" in the cabin when you first walk in. They have a lot of freeboard and are meant to be run standing up.
Revelocity is offline   Reply With Quote
Old 02-28-2002, 03:35 PM   #19
Member #2 ....Jeeezz
cigarette1's Avatar
Toy Boat - Toy Boat - Toy Boat
Quote:
I bought a 1993 27' Fountain with 502EFI, Imco exhaust and a killer stereo system in the Spring of 1999 for $35k.
Gary
cigarette1 is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Who owns a thoroughbred Sick Stinger Velocity 12 03-06-2007 08:51 PM
Tried a Q5X on my Thoroughbred bglz42 Velocity 3 01-25-2005 08:01 AM
26 Thoroughbred For Sale BODYSHOT1 Velocity 1 02-09-2003 09:48 PM
Thoroughbred/Velocity BODYSHOT1 General Boating Discussion 0 07-16-2002 10:37 PM
Search Engine Optimization by vBSEO 3.2.0
