Engine Alarm constant over 4500 rpm >
Old 05-29-2010, 09:47 PM
  #31
Expensive Date's Avatar
Ignition wires?? can't see why that would throw an alarm I am guessing at this point.
Expensive Date is offline
Old 05-30-2010, 06:00 AM
  #32
Pit
Pit's Avatar
Has it run good with no alarms after your new exhaust?
I you suggest leak down and compression test. Also a plug check and make sure the firing order is correct.
Pit is offline
Old 05-30-2010, 06:35 PM
  #33
No but I did not run it this year with the old exhaust and the other motor is fine so I don't think its the exhaust.I checked the firing order three times its right.I did a fuel pressure check good motor was 55-60 other was 35.Changed regulator and it went up to 50.Ran it on a mercury box that replaces the boat wiring harness no alarm (because the alarm was bypassed) but still would not wind and got a little hot there were no numbers on the box gauge so I don't know how hot.I can use a Mercury computer tomorrow morning so see what happens.I have not done a compression or leakdown test yet but its the next thing after the computer.Starting to wonder if I hurt a motor but it runs and sounds great till 3500.Did a cylinder drop test by removing wires off the cap and got an RPM drop each time.Don't know but I am running out of things to check.Impeller is new but I could be loosing water pressure at high RPM but running stopped at 3k it seems to be the same coming out of the exhaust as the other motor.
Old 05-31-2010, 05:40 AM
  #34
try cleaning the grounds on that engine giving you trouble,,,
TWIN-SPINS is offline
Old 05-31-2010, 07:52 PM
  #35
Fixed winded up being a shift selector switch I had it on a mercury computer this morning and it was going into guardian.Why it did not show up when I had someone else scan it I don't know but the ECM thought the port motor was in neutral and would throw it into guardian over 3500 if you held the throttle there.
Thanks to Southwicks Marina in Beach Haven NJ for all there help this weekend.The have 93 octane so if you need fuel stop by.
Old 06-01-2010, 02:13 PM
  #36
Geronimo36
Panther's Avatar
Good deal Tim, glad you got it all squared away and it wasn't a big deal to fix!!
Like I said on the phone, sorry I didn't suggest that, I just didn't think of it!
Panther is offline
Old 06-01-2010, 04:05 PM
  #37
No problem every thing is easy once you find it.I can't believe I did not think of it either.Like the other thread with the 500s cutting out one guy said check the kill switches never would have thought of that.Thats one of the reasons we do theses threads is for the next guy
vandeano
3
08-17-2006 02:01 PM
95caliber
6
07-01-2006 03:57 AM
Dregsz
1
02-02-2006 06:59 AM
Krumbsnatcher
26
07-17-2003 11:43 AM
Cigaretteman
3
11-13-2002 06:08 AM
Quick Reply: Engine Alarm constant over 4500 rpm
