If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. #11
    I would do as Griff suggested, is it the same if you are in the water? If you are sucking in good water flow, then I would check the hoses connected to the T-stat , are they bent so they are restricting the movement of the poppett balls? If I was a betting man I think that the circulating pump is not working right. You have temp problems and the belts on the pump dance around sounds like the two maybe related? Pull that pump off and look at the impellers and check the bearings. l'd take a good look there. Good Luck
    I use the KISS Method when I can't figure someting out!
    K eep
    I t
    S imple
    S tupid
  2. #12
    Registered Shorgasm's Avatar
    Join Date
    Apr 2001
    On the back of a chicks M3..If you're gonna ride my ass at least pull my hair!!
    Oh that sounds easy enough.......I gotta pull the drive apart to do it...... It does the same thing in the water just less noticible......
    I have never let it purposely get too hot.....just adjust the throttle me weird but it's like a reflex.....
    The check balls DO NOT seat all the way on the housing....this I noticed......would that cause it.........
    Before I put the new impeller in it did it too.......but a bit more severe............maybe the housing is shot?????
    I just replace the impeller.....whatta dummy huh?
  3. #13
    Registered birdog's Avatar
    My Boats:
    Top Gun
    Join Date
    Jan 2002
    Batavia Oh.
    I was lucky, A merc mechanic told me way back to always replace the whole thing so i always did. As to those poppett balls ..Dunno. Never had a problem with them!?
  4. #14
    Platinum Member Charter Member
    My Boats:
    Join Date
    Jan 2001
    so. WI
    Definitely put a whole housing/seal kit in when going Globe- the guys with the Bravo engine-driven pumps have had problems with just an impeller change (scored liners).
    After overhauling my engines, one of them didn't have any water output on the hose at all- I used the old engine water pumps (they worked when I took 'em off right?). New impeller & housing kit didn't help. I put on a new engine water pump and good as new!
    There was a pulley alignment problem with the belts on certain 260's and 270's- it generated a service bulletin from Merc to install a spacer on one of the brackets. Check with your local Merc service dept. to see if your serial number might be affected and if it was ever done.
    FYI, my SBC's/Alphas in the Formula act completely different on the hose than submerged in the water- I finally cut down a plastic garbage can to immerse the drive in and just stuck the running garden hose in the can. No more problems running in the driveway.
  5. #15
    Charter Member Charter Member bowtie's Avatar
    Join Date
    Jan 2001
    New Jersey
    The cold water running it on a hose will make the thermostat open and close irregularly. You have to run it in the water to get a true temp reading. As far as the belts, do they squeal? Belts always look wobbly when running at high rpms. Make sure they are all in line with the next pulley. I have to agree with flylevel with the kiss theory. It sounds like your looking for problems you don't really have.
Similar Threads
  1. Winterizing question - good enough??
    By BillR in forum General Q & A
    Last Post: 11-10-2006, 06:10 AM
  2. Question for Too Old & I promise it's not about Joy!
    By SR-24 in forum General Boating Discussion
    Last Post: 02-22-2002, 04:58 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
