If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Page 5 of 5 FirstFirst ... 345
Results 41 to 43 of 43
Thread: hp vs mph
  1. #41
    Platinum Member Platinum Member
    My Boats:
    fuel injection, superchargers
    Join Date
    Jan 2001
    PA and MD
    Tomcat, Those graphs and plots are the best. All of Today's threads have been the best of late. I wish I was at home with a brew. Good stuff.
  2. #42
    Registered 26scarab's Avatar
    Join Date
    Mar 2001
    st. clair shores mi ,us
    You are right I probably am propped right , the HP curve continues to climb the higher I spin it.
    Oh well it was just a thought.
  3. #43
    Registered Whipple Charged's Avatar
    My Boats:
    Engine, speed, powerboats, Outerlimits SV43 with Whipple 1375SCI's
    Join Date
    Oct 2000
    Fresno, CA, 93722, USA
    The factory rev limiter is set at 5080rpm, I would highly recommend not propping so you can hit this. The factory rev limit will cut the fuel, there is a small window where it's lean during this RPM control, especially if you hit it multiple times without lifting (hard to feel in some boats). You should either over prop it or raise the RPM limit. Also, with 5 psi, I would expect around 600-615 crankshaft hp, 650 would be a bit on the high side. The factory injectors are going to be wide open from 550-575hp. Also, the system has to compensate for the 5lbs. of manifold pressure against them to equal the same flow therefore they must compensate for the pressure against them as well as the needed fuel for the 5psi.
Similar Threads
  1. Need last few MPH !
    By gto in forum General Q & A
    Last Post: 09-12-2008, 10:06 AM
  2. How many MPH ?????????
    By sakoutis3 in forum General Boating Discussion
    Last Post: 02-26-2007, 07:25 PM
  3. 80 Mph????????
    By aw61801 in forum General Boating Discussion
    Last Post: 05-22-2006, 07:42 PM
  4. hp for mph
    By jeffg in forum General Boating Discussion
    Last Post: 05-16-2003, 09:26 PM
  5. 68.9 mph to 79.8 mph
    By BILL1134 in forum General Q & A
    Last Post: 06-11-2002, 09:58 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
