If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 22
  1. #11
    Registered Wild's Avatar
    Join Date
    Sep 2001
    St. Louis
    That skeg would be scary at 55mph, not much in the water to steer with
  2. #12
    Registered User
    Join Date
    Oct 2003
    I believe it was Bob Nordskog's cig 39, named CAM... it had detachable skegs. You could pull the pins and they'd drop out while running. I always wondered how it steered though.
  3. #13
    Platinum Member Platinum Member Knot 4 Me's Avatar
    My Boats:
    Join Date
    Jun 2005
    Central IL
    I look at skegs and props the same as I do tires on my vehicles. I want to run the best. I would look for a used, undamaged lower to replace that one with. You only need the casing if you can find one. Otherwise, I'd buy a new casing. If you like the boat and are going to keep it then it is money well spent IMO.
  4. #14
    Charter Member Charter Member Raypanic's Avatar
    My Boats:
    Formula 400SS Eliminator 236 Eagle XP
    Join Date
    Oct 2000
    Lake Orion, MI. USA
    Thats what happens when you "hone your cone" too much
  5. #15
    Registered czy40p's Avatar
    My Boats:
    28 Scarab
    Join Date
    Dec 2003
    Lapeer MI
    I had a cone pop on my drive over winter. The void between the cone and drive had water in it and when the water froze it pushed the the cone loose. I had it tacked on filled the void with fiberglass resin, and used duraglass, so far so good.
  6. #16
    My Boats:
    Join Date
    Sep 2007
    Tulsa, Oklahoma
    Hey - Thanks for all the info - This is only a minor set back - Clean it paint it and fix it over the winter - still some good lake time left in Oklahoma - chao - chef26
  7. #17
    My Boats:
    29' Scarab, Whippled
    Join Date
    Jan 2007
    I had the same problem on mine, just sand it as much as you can put some good epoxy and sand it some more till everything is straight and smooth then paint it satin or silver. Finish the season and put a new lower over the winter, if you look close you can see where the skeg was welded on.
    Attached Images Attached Images
  8. #18
    Registered Brad Zastrow's Avatar
    Join Date
    Jun 2001
    McHenry, Illinois
    There are stress cracks on both sides and top to bottom of the cone which means your cone needs to come off and get reattached. It is loose. Start over or you will fight this every few months. There is no way for the bondo to come off (short of a hitting bottom) if the cone was not moving and causing cracks.
Similar Threads
  1. nose cone good or bad
    By bajabob in forum Drives and Lower Units
    Last Post: 03-12-2008, 02:41 PM
  2. Nose cone, good or bad idea.
    By Fenderjack in forum General Q & A
    Last Post: 08-22-2007, 04:07 PM
  3. Anyone got pics of BAD air shots or landings... I mead bad in a bad way!
    By Waterfoul in forum General Boating Discussion
    Last Post: 04-21-2005, 07:47 PM
  4. Possible bad valv job on SB Vortec heads?
    By BAD-HABIT in forum General Q & A
    Last Post: 03-26-2004, 09:06 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
