Trailering Alert- Recall
had three break right of in my hand when checking tire pressure the tire store replaced all six with what they call hi pressure stems they look like a brass stem with a rubber base good for 90 psi plus
Charter Member # 545
We had two tires out of 6 on a triple axle trailer that had slow leaks. Had a tire go down towing back from Jax. Poker run last year. Lost air pressure and got hot. Put the spare on and it too was loosing air pressure checked it every hour till we got home. Found out it was the valve stems, and they were the high pressure ones with the brass stems. Had to replace all of them.
I need an attorney. !!!
Last year to KW run, on I-75.
NEW rear tire blew.
I'm totaly anal now about trailers and towing with the new boat and new trailer. (I always was, but 10 X more since)
I blamed the accident on faulty tires or road hazard, but always wondered about a rear tire blow out with road hazard, and brand new tire.
This valve thing makes sense.
NEW rear tire blew.
Charter Member #928
Had a friend with brand new Michelins on his truck and heard the recall on the radio. Within 2 days developed slow leaks on 2 tires. People are getting what they demanded and that's cheaper prices, and it all started with Walmart. Guess we should start using prisoners to do the mfg. so we can compete with China for what they pay their people. Damn commies.
On My 2001 Myco I had problem with the factory valve stems,usually would find it when washing the rims/tires, it was usually a slow leak until I hit it with a rag you could hear it hiss then. I had the Goodyear wrangler Ats tires they started blowing out the beginning of last year.Then I replaced all the tires and valve stems.Could of been from being 6 years old?
Ive also had them crack the same way on my trucks dually aftermarket rims
Registered User
Cracking valve stems isn't something new or unusual. It's just with this batch it's happening quite a bit more. I was talking with my neighbor at lunch (He's a multi PhD polymer chemist for a rubber co. ) and he said alot of the Chinese stuff isn't compounded properly for UV and ozone protection.
The conversation then went about 80,000 feet over my head.
