If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Results 1 to 2 of 2
  1. #1
    My Boats:
    Join Date
    Feb 2007
    Fort Lauderdale Beach, FL
    Some Samller Boat "X", Drive Discussion
    Please no TD insights Either.....
    With that said, I am removing my OMC right now to get ready for my winter project. I am replacing it with a Bravo 1 set up. Hopefully an IMCO shorty if finances are there. I had a coversation today with Jim V about new propshaft heights on my 24 Challenger. He recommended about 1.750" from the bottom of the boat. It seemed to be the consensus at Hot Boat with similar 24-28 singles that were fast running in or below 2". We thought I could gain some of the distance by simply raising the motor a bit because I have room and plan on reglassing the transom anyway. Believe it or not, with an OMC King Cobra, the current prop shaft is 7.250". I have to slice out more than 5 inches to get to current schools of thought. Does anyone have an idea as to the actual difference in length between an OMC and Bravo. Mounted in the same location, is their prop shaft the same, up, or down? Thoughts on any real effects of raising the motor two inches? Just looking for some ideas to get the drive height up. Any non TD thoughts would be appreciated.
  2. #2
    Registered PatriYacht's Avatar
    My Boats:
    94 43SC Black Thunder
    Join Date
    Jul 2002
    Part of the height discussion depends on whether the boats used as examples have notched transoms or extension boxes.
    Those will generally allow you to raise the drive more. Raising the drive that much will probably require the use of a modern 4 or 5 blade prop. Until about ten years ago the best prop we had was the Mirage 3 blade. It had to be run very deep. That being said, I would tend to be conservative. Raise it 2 or 3 inches and then use shorter lowers or spacers to find where the boat runs best.
Similar Threads
  1. Summer 2008 Can/Am Georgian Bay Tour - "Discussion Thread"
    By Bobthebuilder in forum Great Lakes and Canada
    Last Post: 01-23-2012, 04:39 PM
  2. OUTDRIVE "B"ring "O"ut "A"nother "T"housand
    By electrical1 in forum General Q & A
    Last Post: 11-09-2006, 08:51 AM
  3. How about a new "Boat Test" or "Dialing In" Section?
    By Harper220 in forum General Boating Discussion
    Last Post: 11-26-2005, 10:44 AM
  4. Official "Sort of Interesting Discussion" Thread
    By fruitta55 in forum Banana Boat
    Last Post: 06-10-2005, 06:18 AM
  5. "Speek Kills" vs "King of Thunderboat Row" vs. "Blue Thunder" ?
    By mikesufka in forum General Boating Discussion
    Last Post: 12-26-2002, 11:23 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
