If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Results 1 to 3 of 3
  1. #1
    Registered 26scarab's Avatar
    Join Date
    Mar 2001
    st. clair shores mi ,us
    How about the "ultimate engine" to go with the "ultimate boat"
    This kind of goes along with the "ultimate boat" thread.
    Think about this , Formula one race cars have 1.5 or 1.8 liter naturally aspirated engines and I believe they make close to 900hp.
    Now using thier technology on a big block it should make some SERIOUS power.
    How about this: 600-700 cubic inch aluminum block, titanium rods, Some sort of trick crank (knife edged throws..etc) , ceramic coated pistons.
    Big chief heads or maybe some custom 4 valve heads
    Sheet metal intake with computer adjusted runners.
    No valve train, or camshaft. Electrically actuated
    Digitally fuel injected.
    Everything controlled by computer, timing , valve lift , cam timing, fuel delivery , fuel pressure .
    Drive by wire throttle control.
    Basically a 700 cubic inch F1 motor.
    I will take two and install them in my 47' custom built carbon fiber/kevlar plush interiored Apache.
    Okay I'm bored at work and just day dreaming !
  2. #2
    Registered velocity260's Avatar
    My Boats:
    2000 velocity260
    Join Date
    Feb 2001
    hmm we had a v16 diesel with alot of torque, that kept of breaking the dyno when I was in school maybe that would work.
  3. #3
    Charter Member Charter Member Ted G's Avatar
    My Boats:
    Marlago 35 FS, 18 Neptune CC
    Join Date
    Jan 2001
    Edgerock Baby!!
    OK now I'm thinking......
    We'll put in variable butterflies in the intake runners and the exhaust system controlled by the computer to change flow velocity at different speeds.
    We will also have multiple computer controlled thermostat valves in the engine to precisely regulate temps-sensors at each cylinder and 4 in the oil pan area.
    Spark will be provided by 4 different plugs at different points in the combustion chamber-each with it's own coil controlled by the computer.
    No liners in the block-it will be silicone-impregnated aluminum like in a BMW.
    Yeah, that'll work.
Similar Threads
  1. The ultimate "poor man's Drive"
    By Quent in forum General Q & A
    Last Post: 04-05-2007, 12:15 AM
  2. OUTDRIVE "B"ring "O"ut "A"nother "T"housand
    By electrical1 in forum General Q & A
    Last Post: 11-09-2006, 08:51 AM
  3. "Speek Kills" vs "King of Thunderboat Row" vs. "Blue Thunder" ?
    By mikesufka in forum General Boating Discussion
    Last Post: 12-26-2002, 11:23 AM
  4. " The Ultimate Boat"
    By shifter in forum General Boating Discussion
    Last Post: 03-16-2002, 10:08 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
