Worth a shot. Any Boston Whaler guru's on here? >
Old 04-12-2015, 03:17 PM
damdonzi's Avatar
Default Worth a shot. Any Boston Whaler guru's on here?
Helping a friend of mine buy his first boat. Looked at a 2005 18 Dauntless. The flex in the center section of the floor directly behind the leaning post was significant. He is getting a survey done, but I wanted to check and see if this might be a known issue. I was shocked when we got on board. It appears the entire center section of the floor can be removed with screws to gain access to the fuel tank.
damdonzi is offline
Old 04-12-2015, 03:22 PM
I havea boston waler. I love it .
had to do floor work as well .
mine is completely filled with foam
hard to work around it.
if it s cheap enuf ,is the thing
it will never sink.
klaatutooyou is offline
Old 04-12-2015, 05:12 PM
i will offer to cut it in half for you like to do in their commercial to prove they are unsinkable, if yours sinks you will immediately know its a china splash
iliveonanisland is offline
Old 04-12-2015, 05:13 PM
Post on www.continuouswave.com
Those guys know Whalers!
Jupiter Sunsation is offline
Old 04-12-2015, 05:52 PM
damdonzi's Avatar
Agreed.
damdonzi is offline
Old 04-13-2015, 06:56 AM
screamandfly.com will get you good results.
Old 04-13-2015, 01:29 PM
whalers are good boats,,,,,
like any boat with a screwed down acess cover
water gets in through the screws and can rot the wood through time,,,,
is rest of floor around the cover stiff ?
should be as stated rest of hull is foam filled
if so ,,,,and get boat a a good price
pulling the acess cover to have reglassed is pretty common on lots of fishing and ski boats
with screwed down acess covers
johnmiffco is offline
