If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. #11
    Platinum Member Platinum Member JRider's Avatar
    My Boats:
    Join Date
    Jul 2007
    Quote Originally Posted by delsol View Post
    careful if you are running thermostats, be sure engine is up to temp -- thermos are open. You might see anti freeze come out the tail pipes and still have 100% water in the block otherwise.
    It is always good to pull the drain plugs from everywhere in order to allow flushing of any sand or crud that has gotten stuck in the water jackets over the year too.
    I first loosen the block plugs and water seperator to finger tite. I get mine up to temp on the hose, shut it off, quickly take out the finger tite plugs, drain block, dump separator and add 2 stroke oil, replace plugs, switch my home-made Tvalves from water to the tank of antifreeze on swim step, restart engine and run 10 gallons or more of antifreeze until the motor bobbles or dies from the 2stroke oil.
    I do it this way to avoid pulling hoses. Bye the way I have 3 bypass holes in my 126* thermistat. So...even if the tstat did not open my block would fill with antifreeze. I also place a large storage tub below the drive to catche antifreeze that leakes from the boot on the drive. Next year I think I will rig up some kind of flexible tubing on the exhaust to direct the discharged antifreeze into the storage tub also....It kills your grass like roundup!
  2. #12
    Registered Airpacker's Avatar
    My Boats:
    little cat...BIG MOTOR
    Join Date
    Aug 2001
    Aurora Ontario
    Quote Originally Posted by daredevil View Post
    WOW, we never put AT in the motor.
    I heard it can damage it if sitting in there????????????
    But dont know ,just curius ! Dont get put on a wrong track from me.
    You can always bring your boat to FLORIDA, it dont freeze here.
    anti freeze is loaded with corrosion inhibitors. It doesn't eat holes in your trucks engine block does it?
Similar Threads
  1. need a bravo 1 w/ low water pick up
    By dreamer in forum General Boating Discussion
    Last Post: 07-17-2007, 05:24 PM
  2. Low Water Pick-up vs Thru The Hull Pick-up
    By Shah Mat in forum General Q & A
    Last Post: 12-29-2004, 03:50 PM
  3. low water pick-up opinions
    By voodoo in forum General Boating Discussion
    Last Post: 08-05-2003, 12:37 AM
  4. Can I add the standard water intake holes to my low water pick up drive??
    By Waterfoul in forum General Boating Discussion
    Last Post: 04-17-2003, 08:01 PM
  5. Low water pick-up?
    By Quest for Speed in forum General Q & A
    Last Post: 02-19-2003, 07:56 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
