If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Alm. Blocks
  1. #11
    Registered Ratickle's Avatar
    My Boats:
    43' Black Thunder, 39' Scorpion, 24' Empress, 10' Bonanza
    Join Date
    Feb 2006
    West Michigan
    Isn't the Ilmor V10 all aluminum and they have been having good results with it even in salt.
  2. #12
    Registered Platinum Member
    My Boats:
    39' Sea Ray, 38' Nortech, 18' Taylor SJ
    Join Date
    Jun 2006
    Lake Conroe, TX.
    Stick with Iron. THe corrosion factor isn't worth worrying about.
    Stick with 598 also. You will make just as much power as the 632, and it will last longer.
    Good luck.
  3. #13
    Registered JIMKID Motorsports's Avatar
    My Boats:
    2009 30 LS7 SKATER 711
    Join Date
    Mar 2001
    Livonia Mi Usa
    Im building two LS7 all aluminim small blocks for my 30 skater go closed cooling and dont woory about corrosion i had to keep the weight down so thats why we went this way they are 460 cubic inch 700 hp all day long efi naturaly aspirated cant beat it should be interesting
  4. #14
    Join Date
    Jul 2008
    My Experience
    Quote Originally Posted by redcorvetteman3 View Post
    For you experienced engine guys out there ... What would be the pro's and con's of using a all aluminun motor in fresh water. Except for the price. Would they have as much durability as iron blocks in a N/A 598 or 632. Would the weight savings be notable in a twin 40 ft V
    My Ilmor 710 is all aluminum and fresh water (closed loop) cooled.
    In fresh water there is little to no downside using an open loop aluminum block. Salt should be closed loop.
    They are as, or more durable than iron. Unlike an iron block they can also be repaired when you kick a rod out of the side. This is why there is such a robust aftermarket for them - if you take care of it it can last a lifetime. The aluminum "expansion issue" was solved decades ago by companies like Donovan, Rodeck, GM etc.
    (Donovan can let you REALLY build a big engine) Steve Schmidt builds these a lot.
    Most prestigious builders DO offer an aluminum option for a substantial extra premium of 2-5K a block. It's not always on the parts sheet but a quick phone call will get you an already memorized uplift quote.
    The weight savings are are at bout 200LB over standard big block. On a twin engine boat or a 21ft river runner this is a big difference.
    The downside comes when you
    1. Have to bold accessories TO it that require more than a few lb/ft of torque- you cant just let a a line mechanic jab around it- you need to be really careful hell pull the threads out- you pretty much need to helicoil all heavy torque threads.
    2. Cut the check.
    Uncle Dave
    Laveycraft 2750 -710
    Laveycraft 20.8 Sebring
  5. #15
    Registered PatriYacht's Avatar
    My Boats:
    94 43SC Black Thunder
    Join Date
    Jul 2002
    The aluminum between the cylinders is very thin because of the sleeves. You have to check how deep the head bolt holes there are threaded and get head studs that are longer than normal to thread into them. If you use regular studs, you'll pull the aluminum right out from between the sleeves.
    The weight savings is at most 150lbs. An iron Merlin block is 260lbs and a Chevy block is lighter than that. Using aluminum heads saves about 45lbs ea. Times two for a twin engine boat you save 4-500lbs. In a smaller twin engine boat like a 30' Scarab or a 27' Magnum it would really make a difference. In my Black Thunder, not so much.
Similar Threads
  1. blocks
    By redcorvetteman3 in forum Wanted
    Last Post: 05-15-2008, 08:08 AM
  2. Blocks
    By Sulfur1 in forum General Q & A
    Last Post: 12-11-2007, 12:01 AM
  3. Tall Blocks
    By Fenderjack in forum Fountain
    Last Post: 01-04-2007, 03:03 PM
  4. Aluminum Blocks
    By Steve A.K.A RAMPAGE in forum General Q & A
    Last Post: 01-11-2002, 12:31 PM
  5. aluminum blocks vurses iron blocks
    By badbug in forum General Q & A
    Last Post: 01-08-2002, 01:29 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
