Go Back   Offshoreonly.com > General Discussion > General Boating Discussion
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 11-21-2008, 09:28 AM   #11
oklaoutlaw
Quinlan's Avatar
02 38 T/S GUN 43 Wellcraft Portifino
Had a friend pulling a 272 baja it was only a single with a 2500hd chevy came up on a stop to fast no brakes on trailer jack-knifed and slid across 4 lanes of traffic!! No one hit him unbeleivable they didnt!!!
So pulling some twins with a 1500 all I can say is GOOD LUCK during the emergency stopping!!
Quinlan is offline   Reply With Quote
Old 11-21-2008, 09:38 AM   #12
TexomaPowerboater's Avatar
1990 28 Apache FOR SALE, 03 Sea Ray 240 sundeck
Quote:
Originally Posted by spilman View Post
A 27 fever that is 29' long???huh A 32 fever is 27'-9"; I'm not sure if the older fountains were longer??
btw, what does that twin bb look like in the water? Does it porpoise at speed?
Why cut down the guys boat when all he was trying to do was help the guy out? AT's aren't perfect either.
I do think his weight is off. Mine doesn't weigh any more than 9000lbs full of fuel, including the trailer. When his boat was made they didn't count the swim platform in the length.
I think the suburban would be maxed out. Loaded full of people - probobly over capacity.
TexomaPowerboater is offline   Reply With Quote
Sponsored Links
Old 11-21-2008, 09:45 AM   #13
Forum Regulator
Sydwayz's Avatar
Active Thunder 37' & other Factory boats, 13' Mini Hawk
WAY over what you want to tow with a 1/2 ton Suburban. Check the first post in the truck/trailer section, and you can find out your exact capacity.
The biggest pitfall is the coil-spring rear suspension in that Suburban. It's the equivalent of a Chevy Cavalier with stiffer springs. One bad hop from the heavy tail end of that twin engine boat, and the back of that Sub is going to be all over the place; and the coil-springs are going to rebound back and forth and front and back, until you are upside down. Top that off with all your passengers, and your in truck cargo, which is already on the rear axle, and also now in peril.
Don't do it.
The most you want to tow with ANY 1/2 ton SUV is about 7500 lbs, which is an average 25-28 foot single engine boat.
Brian T.
Active Thunder Factory Rep.
Web: ActiveThunderBoats.com
Email: brian(a)activethunderboats.com
Sydwayz is offline   Reply With Quote
Old 11-21-2008, 02:13 PM   #14
81 sea ray 26SXL T-350's
Robyw1, I Pull my sea ray with my yukonxl 1500(has autoride though) across no. mich. 2-3 times a summerand pulls and handles just fine. Wouldn't want to haul much bigger though...
26sxl is offline   Reply With Quote
Old 11-21-2008, 02:14 PM   #15
fund razor's Avatar
Apache 28 Brave
Quote:
He was asking how a 27 foot Fountain is 29 feet. His question was answered. He was not cutting Prostock down. In fact, Prostock is currently enjoying quite a bit of support around here. You?
ATs have nothing to do with it either. That was you trying to poke his boat because you perceived that he poked another's.
Not sure that Prostock needed your protection, Nancy.
fund razor is offline   Reply With Quote
Old 11-21-2008, 02:21 PM   #16
Robyw1,sorry,and by the way , would I want to haul it to Fla. from here with my yukonxl or any real long dist. trip....NO.....
Old 11-21-2008, 02:25 PM   #17
tssteph's Avatar
1998 AO 31
I towed my 29 scarab with twins and a steel trailer once with a half ton extended cab chev with the 5.3. I had brakes on all thre axels on the trailer. It was more then the truck wanted. It will work on flat ground but I would not do it long term. I upgraded to a 6.0 liter chev 3/4 ton and it did fine.
tssteph is offline   Reply With Quote
Old 11-21-2008, 02:33 PM   #18
Is it fun sitting on the shore? For a moderator on SOS you sure do spend A LOT of time here.
Old 11-21-2008, 02:41 PM   #19
20 Playbouy -Challenger Super V24
Maybe "Pocket Change" and myself shouldn't have been using my Expedition to pull our 42 triple Fountains around?
MidnightRider is offline   Reply With Quote
Old 11-21-2008, 03:01 PM   #20
fund razor's Avatar
Apache 28 Brave
You, as usual.... have no clue about what is going on and who is who. Nancy.
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Thoughts on 29' Scarab Viperbob Scarab 11 09-12-2008 10:37 PM
29' scarab cperry28 General Boating Discussion 3 06-08-2008 08:21 AM
air conditioner in 29' 1995 scarab budruss Do It Yourself, Boating on a Budget 1 06-03-2008 07:01 PM
Thinking About Purchasing A 29' Scarab..... 86RedRocket Scarab 14 03-10-2008 12:02 PM
Water Separating filters 29' Scarab No Limits ! Scarab 2 03-14-2005 02:10 PM
Search Engine Optimization by vBSEO 3.2.0
