Iron Heads
Old 01-14-2009, 07:00 AM
Thanks Guys Keep The Comments Coming. I Have Dart Iron Eagles Fully Ported By Valako. My Engines Was Na 700hp 572ci I An Supercharging Now.my Comp Was 9.4 To 1 And Solid Roller Cam. Lowering Comp To 8.75 To 1 And 5 Lbs Of Boost And Hyd Roller Cam. Almost Everyone Telling Me To Change My Heads To Aluminum Because Iron Heads Will Not Work But Iron Heads Flow So Good It Is Going To Cost Me Alot Of Money To Get Heads With That Kind Of Flow #s. What Do U Guys Think. Thanks
cigarette39 is offline
Old 01-14-2009, 07:25 AM
CNC
CNC's Avatar
Originally Posted by cigarette39
Hi Anyone Using Iron Heads On Supercharged Engines. If So How Much Boost And How Reliable Are The Engines. Thanks
Dart CI heads w/M-4 procharged 12lbs boost 1078 hp on 93 pump gas no problems
CNC is offline
Old 01-14-2009, 07:27 AM
Here Is The Flow #s. Dart Iron Eagles 308 Ported To 330cc Intake Runners :intake 100-68, 200-156, 300-234, 400-301, 500-350, 600-380, 700-391. Exhaust 100-60, 200-143, 300-199, 400-249, 500-275, 600-292, 700-302. Lots O Work Done To Them.
Old 01-14-2009, 08:04 AM
KAAMA's Avatar
Originally Posted by Mbam
kind of -
http://www.go-fast.com/bam,_the_project.htm
We actually pulled it in the shop today to take a look, might at least finish the glass work
Marc, that was a GREAT read on the link you gave about your boat---not just on all the mods you did to your boat, but also I would say that was "back in the day"---it took me back to the early 1980's.
I remember seeing your red 36' Cig/"BAM" periodically as you, Mike Freeman/"DINASOUR" with his yellow 38' Bertram, and the two other black Cigs, "SMOKIN" and "BEAST"
coming over to the west side of Lake Michigan for the offshore races in Saugatuck/and or Grand Haven.
In 1986 I met Jimmy Ariola/"SAVAGE" and his 32' Hustler w/arneson drives, Matt Alanza/"MALINDRINO" and his 30' Carrera, and the husband and wife of "HOMEWRECKER" another 30' Carrera, Scott Duvall and his 30' Carrera and several others from Chicago and Michigan City-----they all came to St. Joseph for the "U-GOTTA REGATTA" weekend. It was a fun run from St. Joe to Saugatuck with stops in South Haven on the way there and back. It was a lot of fun.
You and all the people I have mentioned had offshore boats "back in the day" when I still considered the Offshore Powerboating and the Great Lakes as one of America's final frontiers---I still do, but not quite to the extent it was in the 80's with all the restrictions, etc.
By the way, I don't know if you have already done this yet, but if you haven't yet taken your boat up to Grand Traverse Bay area or Charlevoix, then you should at least ONCE before you're too old.
KAAMA is offline
Old 01-14-2009, 04:12 PM
Registered User
just my 2-1/2 cents
Worked on tons of supercharged engines with plain ole 088 chevy heads. Don't make as much power as the fancy aftermarket heads but pretty much bulletproof and a hell of lot cheaper
29Firefox is offline
Old 01-14-2009, 05:22 PM
AIR TIME's Avatar
Thumbs up
kind of -
in 1994 keywest I saw the boat at a slip it looked like you had two tail pipes that were 8'' around and the red paint was cool, do you have a few pics to show her off on here that boat looked cool. good luck artie
AIR TIME is offline
Old 01-14-2009, 06:02 PM
Rob
Strip Poker 388's Avatar
alum would be nice but my steel ones doing fine
http://www.offshoreonly.com/forums/g...tq-839-hp.html
http://www.offshoreonly.com/forums/g...-build-up.html
Strip Poker 388 is offline
Quick Reply: Iron Heads
