(Post 2789182)
what are the dimensions of the opening? I may have some options
Originally Posted by ROTAX454
(Post 2789854)
Hey Dave, Remember my problem with height and hatch clearance? Do you remember the solution? I too needed only 3-4 inches max of clearance. I also didn't want to cut the sunpad open for exterior scoops.
Mike wrote:
Do you have any pictures of them, would be interested to see
Originally Posted by mike tkach
(Post 2789289)
i had a 32 baja outlaw that i put blower motors in.i cut holes in the hatch,made boxes from .125 aluminum,mounted them in the holes and made a new pad for the hatch out of high density foam,i used 6 in thick foam instead of the origional 2 in foam,then called baja,they sent me new material to put over the foam,when it wad done,it looked like it came from baja that way.
Mike wrote:
I had the 525SC motors with the intercoolers and I had to cut the air filter down and it was no problem, but with these motors, they are 4 inches taller
Originally Posted by Back4More
(Post 2789774)
This is a shot of a 33 with 575's I can't see why even 8-71's wouldn't fit in there...are you running innercoolers? Rasied carb flanges? What is the distance from the crank centers to the top of the flame arresters
Innercoolers on the new ones also?
Mike wrote:
Yes, the new motors have the intercoolers below the 1471 blowers
(Post 2790476)
Ditch the innercoolers...you'll never need those under 14-71's
