Go Back   Offshoreonly.com > General Discussion > General Boating Discussion
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 02-13-2009, 04:57 PM   #21
mwdill's Avatar
02 HUSTLER SLINGSHOT
Quote:
Originally Posted by Strip Poker 388 View Post
Hustler wants $500.00 for the ladder and 2 years ago it was $250,I snoozed We tried getting the screws/bolts out of the Ladder tonight,it started cracking the fiberglass, it must have the nut style, nut inserts made into the swim platform when the boat was made,and must of been installed with no anti seize its not accessible at all. Any suggestions?
i have not messed with mine yet , but sounds like fun
might mess with it in the spring, might have to get the cuting saw out :
mwdill is offline   Reply With Quote
Old 02-13-2009, 05:53 PM   #22
augie58's Avatar
98 formula 353
If an auto finish (dupont, ppg, sikkens) is used what is the tolerence to being in the water. Would being in the water for a weekend or a week cause problems?
life is an incredible journey--might as well live it large
augie58 is offline   Reply With Quote
Sponsored Links
Old 02-13-2009, 10:04 PM   #23
32storm's Avatar
Boatless....
Quote:
Issue is usually with 2-stage(base-clear)vs with a single stage. A 2-stage is more prone to bubbling between clear & base coats. But, a weekend or week shouldn't be an issue.
32storm is offline   Reply With Quote
Old 02-14-2009, 12:19 AM   #24
Rob
Strip Poker 388's Avatar
Hustler 388
Quote:
Originally Posted by daredevil View Post
Drill them out with a small drillbit and then they usualy come lose !!!!!
but if it doesent come out and breaks off the head or pulls out or spins the insert.Ill have to cut into the swimplatform,
Im guessing this or a nut is made into the fiberglass
Strip Poker 388 is offline   Reply With Quote
Old 02-14-2009, 04:25 AM   #25
2000 Donzi 38ZX
Paint it!!!
Donzi38ZXXX is offline   Reply With Quote
Old 02-14-2009, 11:22 PM   #26
Marine Surveyor
None
Paint is much easier to clean than gelcoat, however I have seen paint bubble if the boat is left in the water for a long weekend.
Athiests better pray they are right.
Edward R. Cozzi is offline   Reply With Quote
Old 02-15-2009, 01:43 AM   #27
Rob
Hustler 388
Quote:
Ed I Hadnt had any bubbleing with the factory paint on the sides.maybe it was preped right?
Old 02-17-2009, 04:58 PM   #28
HotShot
Brent Medley's Avatar
Top Gun 600th Edition
Strip,
Just painted my transom.......only regrets is that the paint shop did not take out my exhaust tips because they were afraid of stripping the screws....wish they would have anyway as I would have installed new tips.....only so close they could get around the tips for sanding
Brent Medley is offline   Reply With Quote
Old 02-17-2009, 08:33 PM   #29
Get Down
Rcrapsey's Avatar
18 Ft. Ventura RIB
I tried many times to get Donzi to paint my transom while it was being built , no way.
Couldn't get a reason that made sense to me. Can anyone fill me in on the reason some builders don't paint the transom?
Rcrapsey is offline   Reply With Quote
Old 02-17-2009, 08:43 PM   #30
aka Rump Shaker
2002 38'Ocean Express Catamaran
Quote:
Originally Posted by paintkahuna View Post
Not trying to dog the Imron guys, good product, but is it paint for heavy equipment or dump truck beds. Use a good base coat clear coat paint. PPG, sikkens. And if you bump into something at the dock it is easily repaired.
My whole boat was painted in PPG in 2001.. it has been in Fl, and all up and down the east coast. Not a flaw in it.. PPG and a lot of clear.. I got tapped at the sarasota spring opener by another boat docking.. Piece of cake to fix can't even tell anywhere it has been touched up!!
mmareno is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
gel coat over paint / clear coat ?? Chris288 Fiberglass and Paint 7 09-20-2007 05:31 PM
clear coat vs gel coat Fenderjack Fiberglass and Paint 14 02-14-2007 08:22 PM
Gel Coat JJONES Fiberglass and Paint 6 10-12-2006 10:36 PM
Clear Coat over Gel Coat pb Fiberglass and Paint 7 08-24-2005 02:19 AM
How much gel-coat cand be removed before having to re-gel? Pure Energy General Boating Discussion 9 02-21-2003 08:05 AM
Search Engine Optimization by vBSEO 3.2.0
