If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. #11
    Registered Roger 1's Avatar
    My Boats:
    1993 Cigarette Top Gun
    Join Date
    Dec 2002
    Kankakee Illinois
    Quote Originally Posted by Sydwayz View Post
    One thing that is overlooked is how the Castle Nut is retained. I prefer the old fashioned cotter-pin though the spindle method, but most of the new trailers with grease-zerks in the end of the spindle can't use this method. They have these Axle Tang Washers where you bend one tab over into the Castle Nut opening. I think they suck, but what can you do?
    You can break off those tabs with your Crescent wrench, and so can a little pressure/twist from a heated bearing. As soon as that tab is gone, your wheel will be gone within a mile.
    Next time I redo bearings I am going to double up on the Axle Tang Washer.
    It's alway nice to be able to doulble up on the ''tang''.
  2. #12
    CNC is offline
    Registered CNC's Avatar
    My Boats:
    31 AwesomeCat
    Join Date
    Sep 2003
    Ludington, Mi.
    Brian thank you again,
    Those were great threads and answered all all my questions, I just used the wrong search words. NO oil bath for me
  3. #13
    Forum Regulator VIP Member Sydwayz's Avatar
    My Boats:
    37' Active Thunder AVH; 17' Speedliner Cat OB
    Join Date
    May 2001
    My pleasure Randy.
    And Roger; the only thing better than Double Tang is Triple Tang+.
  4. #14
    Registered VIP Member HotPursuit's Avatar
    My Boats:
    40 Skater
    Join Date
    May 2004
    I have a Skater trailer with oil in the hubs.As long as your not going to dunk it they work great.I have installed new everything seals bearings covers and they still get milky after 1 trip under water..Im going to grease.
  5. #15
    My Boats:
    32 SeaCraft
    Join Date
    Jun 2004
    Freehold, NJ
    You will almost always get water in the oil hubs, it happens with big trucks everytime the doopey driver go through a flood and here's why.
    The grease hubs do not have vents to let pressure out. When you look at a typical grease hub it has a sealed outer bearing cover like on the front end of a car. Grease seals are generally a non-unitized seal and any pressure build up can escape through the seal itself.
    With oil hubs you have a vent because most have unitized type oil seals and those seals are non-breathable, there is a vent hole on the cap or cap plug to releive pressure as to not damage the seals.
    When you put the oil hub trailer in water, even if the axles are only 1 ft under water the pressure outside the cap is greater than inside and water will leak in through the vent.
    Also, as you know when there is any bearing temperature at all, the cooling of the hub in water creates a contraction which draws in water. The grease seal because of the double lip design will hold the water off more so than the simple hole in the rubber hubcap of an oil hub.
    These factors draw the water in the hub and it is allmost impossiable to stop that.
    The seal of the oil hub is far superior to that of a grease hub and aside from that vent slot oil hubs are perfectly fine if not better to go underwater than grease hubs because of seal design itself.
Similar Threads
  1. melted gimbal bearing grease ????
    By mjb in forum General Q & A
    Last Post: 07-09-2008, 11:50 AM
  2. BRAVO I Gimbal Bearing Grease Fitting ???
    By tpenfield in forum General Q & A
    Last Post: 07-05-2005, 07:27 PM
  3. Best trailer wheel bearing grease
    By FlyFast in forum General Q & A
    Last Post: 05-25-2004, 11:12 PM
  4. Wheel Bearing Nut????
    By Steve A.K.A RAMPAGE in forum General Q & A
    Last Post: 05-08-2003, 07:18 PM
  5. Lining up grease hole on gimbal bearing
    By blackhawk in forum General Q & A
    Last Post: 05-05-2002, 08:33 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
