Looking at a Baja 272 got a few questions....???? >
Old 03-15-2009, 07:20 PM
Default Looking at a Baja 272 got a few questions....????
Found a Baja 272 locally for a pretty decent price, and its a very clean boat, had a survey done and it came back with no problems.
Had some questions about the boat. Owner says it has been out of the water since 2002, the boat is a 94 and he is the second owner purchasing it in 1996.
What are things to look for in the drive? Bellows, Gimbal bearings, water pump?? The drive is a Bravo one, behind a Mercruiser 454. The boat has been in inside heated storage since winter of 02.
Thanks in advance!
SmurfOnABoat is offline
Old 03-15-2009, 07:42 PM
i don,t know what engine the boat has,or how many hours are on it,but at the least,you will need to drain the fuel,replace the battery,replace water pump impeller,change oil&filer,and drive lube.unless the deal is really good,insist on a water test before bying the boat.good luck.
mike tkach is offline
Old 03-15-2009, 07:50 PM
2 Brand new batteries, 281 hours.
Yes we already agreed to a pre-purchase water test run.
Old 03-15-2009, 07:54 PM
Thanks in advance!
make sure your surveyor hammered the stringers real well. I've seen more than one of those older bajas with delamination. If it's been kept as dry as you say it's probably in good shape. Bellows bearings and waterpumps are just maintence items no big deal.
Sunshadow is offline
Old 03-15-2009, 07:57 PM
You should look into this one...Very nice boat and priced right. Wouldnt have to worry about any thing just put it in the water and go.
http://midwestboatparty.com/forum/4s...duct=352&cat=4
I bet he would consider even meeting half way too.
And no its not mine
myscarab30 is offline
Old 03-15-2009, 08:00 PM
Nice boat, but going older. This boat is 3 years newer and still cheaper
surveyor is NAMS accredited, he said the stringers were ok.
Old 03-15-2009, 08:09 PM
Good luck then. As soon as you own it two footitus will kick in then you'll need another 100 hp then a twin with big power have fun.
Old 03-15-2009, 08:19 PM
Yes, twin will definitely be my next boat no questions.
But this one has mods starting right away if I end up getting it. At the shop I have a new Stage 3 whipple kit sitting there for a MPI motor.
Old 03-16-2009, 10:38 AM
Never Enuff
Go to the Baja section. There are a bunch of guys that worked at the Baja factory that can probably give you some ideas of what to look for on that specific year Baja.
Jay
never enuff is offline
Old 03-16-2009, 10:47 AM
Thanks...
Any mods out there, could you move this thread to the baja section.
I would greatly appreciate it!
gtxjoe
Baja
16
12-19-2020 08:04 PM
Preuni
2
12-04-2005 03:29 PM
slider1
Powerquest
24
07-11-2005 11:17 AM
JLS
Baja
2
08-26-2003 12:15 PM
737jetmech
Baja
5
11-19-2002 09:11 PM
Quick Reply: Looking at a Baja 272 got a few questions....????
