lesson on twin stepp take off
#41
can you think of a reason why your friends were reversed?
#42
[QUOTE=omerta one;2831857]
great info thanks!
how do you find the neutral position on the outdrives on a boat?
do you start by leveling the boat trailer and then level the outdrive cavitation plate??
The reason is if the drives are tucked 'too' far at speed in a hard turn, it is more likely to spin-out/roll a twin stepped hull due to the added stern lift. I never have my drives tucked all the way in when turning (rule #1 of driving a stepped hull). QUOTE]
The drives should not be trimmed below level when turning at speed...period.
#45
like on reply#32 the bravo drives come with a spacer,the only difference is the location of the spaces,front or behind the ram bolt, on bravo 1 the spacer is located in front and on bravo 3 the spacer is behind,mine where reversed,wont know if thats my problem until I go out again.
No, I wasn't clear. The spacers were between the upper and lower housings, to put the prop in deeper. I think they were only 1" spacers. He never had any blowing out like you are experincing, so I'd have to assume the 1" spacers did the trick.
#46
Do not trim below that when turning at speed.
#48
Charter Mod
Boatnt,
Probably won't tell ya anything you don't know but....
Last year I bought a '02 340 PQ with 496HO's and 28 B-1's twin step. I was having quite a learning curve coming from a single 330 Bravo with a 23P.
Two things that helped me:
Drives down deep and full tabs. As she starts to nose back down and come on plane, I trim the drives and lift the tabs.Feels like something kicking it in the azz.
Secondly, I just raise the rpm's to about 1200-1500 for 10-20 seconds to get the speed up a bit while the hull is still in the water, Before I really try to get it on plane. But Yeah, If trying to get it on plane over 3500 RPM she'll blow out.
Just by getting the hull speed up a bit before take off makes the tabs full down less required
BTW Beautiful boat and congratulations!! If ya make it to Northern Lake Mich give us Charlevoix / Boyne guys a buzz.
