If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
  1. #21
    Platinum Member Platinum Member 1BIGJIM's Avatar
    My Boats:
    Pachanga Twin 502s Bob Mandra Cams
    Join Date
    Jun 2004
    Omaha, Nebraska. Boat on the Mighty Mo! Longest river in the USA!
    Quote Originally Posted by Shallow Minded View Post
    Hey Jim,
    You'd probably be fine... but if you think you're cutting it close, just drop a shop light in the bilge. Or, if you don't trust Jim Flowers, run the juice through it. Now post some pic's!!!
    I don't have access to a plug in at a motel for the one night I might spend in Kansas
    Here is a picture. Stored in a big garage and only used a couple times a year. New engines (454's) have only 40 hours on them. The only thing original are the blocks.
    Attached Images Attached Images
  2. #22
    Charter Member # 55 Charter Member Griff's Avatar
    My Boats:
    ..........32........... Active Thunder
    Join Date
    Oct 2000
    I think you are fine. An overnight low of 25* is nothing to be worried about. It'll be 25* for a couple hours before it warms back up. If it was going to be for more than 12 hrs, I would at least drain the blocks.
  3. #23
    My Boats:
    2000 42 Lightning
    Join Date
    Feb 2006
    Man you can never be to care full. Spend the few schillings and put the pink stuff in. Hell it is only a few bucks instead of thousands.
  4. #24
    Gold Member Gold Member
    My Boats:
    Wellcraft Excalibur 26
    Join Date
    Feb 2006
    Cicero, NY
    Cant you just pull the upper hose of the water pump to dump AF in?
    I think this will get down to the block but not the drive and take about 2 minets with just a flat head driver.
  5. #25
    Join Date
    Feb 2009
    Pardon my thinking but,
    Why don't you pull the plugs from the block's and let the water drain out? Exhaust manifolds too!
    Be sure and stick a piece of wire in the hole's to clear out the mud and rust that usually blocks the water from exiting. Water will run out when the plugs are removed unless blocked by rust and mud.
    If you are concerned about marginal time under freezing or a weatherman that gets paid the same for a bad forecast, Just Drain it and don't worry.
    Your power steering fluid cooler, engine circulation pump, water pump are not protected BUT they have rubber hoses attached that expand. Your goal is to protect the Major components for worst case.
    Anti-freeze is ok but engine thermostat must open before it protects the block. Remove water and nothing can be damaged period. The block or metal does not sustain damge from cold weather or freezing. Damage is from water expanding as it freezes.
    We get back and forth weather in Dallas. Beautiful then a freeze overnight.
    Good Luck
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
