Jasper Marine engines
Jasper
I had a terrible experience with Jasper, but it was on 500HP engines. There was a Jasper guy in New England who said he could build high performance engines. First there were all kinds of problems just to get them running, then once we did the first motor popped in about 15 minutes. After bringing them to JC performance (after getting no help from the Jasper Rep) he told me the compression was so high I would have had to run over 100 Octane for the engine not to detonate. Jeff fixed them up and I never dealt with Jasper again. Just my experience. I guess if they're already in a boat and are running good they should be ok.
Find a good local Seattle shop -mechanic and have them or yourself go to GM and buy the engines as crate longblocks in the 300HP version and switch them out. Just make sure they use brass or stainless freeze plugs and use the crate long block that matches your engine years cylinder heads for intake manifold correct bolt up. You will get good new engines this way and have a GM warranty.
Best Regards,
Ray @ Raylar
Best Regards,
Ray @ Raylar
JIM H
I agree with magicfloat. I used them at my car repair shop for years and never had a problem. I must have installed 25-30 of them.
I used them in a formula & bertram and the same thing no problems.
Good luck
Good luck
