OIL PUSHING UP OUt of DIPSTICK 7.4 MPI >
Old 04-21-2009, 06:26 PM
Default OIL PUSHING UP OUt of DIPSTICK 7.4 MPI
I Have Oil Commig Out Of Dipstick , And Low Spark At The Plugs Can Anyone Help Thaks James
jimmie is offline
Old 04-21-2009, 06:32 PM
sounds like two different problems to me, oil out off the dipstick?????? my first guess would be cracked head or head gasket or any other water passages within the engine that would let water in. I'm assuming you do not have a closed cooling system of course. Low spark total different senario. For your sake I hope your mechanically inclined or have friends with wrenchs
Hot Stepper is offline
Old 04-21-2009, 09:26 PM
Ona-Mission's Avatar
I get oil out both of mine also. I've tried to fir orings and gaskets for a better seal. Sill no luck.
Ona-Mission is offline
Old 04-21-2009, 10:15 PM
Oil out of the dipstick means the block is being pressurized.(or over ful) Check the PVC valve or the vents on the valve covers.The spark problem could be the coil but they usually work or not.How did you check the spark?What makes you think it's weak?Is it all cylinders?If it's just one cyl,bad plug wire,high resistance.
Bob280Silencer is offline
Old 04-22-2009, 10:50 PM
Received 1,491 Likes on 806 Posts
daredevil, drill 1/8 th inch hole in your tube about an 1" or 2" from the top and install a light weight spring. I had that happen with my old blower engines.
getrdunn is offline
Old 04-23-2009, 07:30 AM
seafordguy's Avatar
Originally Posted by daredevil
My engine has 12.5 :1 compression ,,,and i always get oil pushing out of the dipstick ,,,NORMAL
befor i take it out i ducktape the dipstick !!! SIRIUS !!
No joke .
I take about a 1.5x1.5 piece of duct tape and run the dipstick right through the middle of it then simply push the dipstick into place. The tape "folds up" under the tube and whola - problem solved.
I've never had much come out but enough that it bugged me...
seafordguy is offline
