bravo 1 gear oil can? keeps beeping. >
Old 05-26-2009, 05:55 PM
noyzee's Avatar
Question bravo 1 gear oil can? keeps beeping.
why?
496 mag stock on my 03 checkmate. i went for a ride a couple weeks ago thing started beeping. figured it out, put a screwdriver in there, mushed it around and it shut down. great. next day i went out again, same thing, put the screw driver back in, didnt do it. unplugged the wires and it was fine when i plugged it back it.
this weekend went back out thing wouldnt stop, so i just unplugged it and drove home.
whats up with that?
does it matter if its unplugged till i get a new one? i know its full, its not leaking, never had an issue befor. what could it be?
any info?
noyzee is offline
Old 05-26-2009, 06:14 PM
Neno the mind boggler
glassdave's Avatar
I've gone through a few on the Donzi its not uncommon for them to get sticky or just go bad. Not sure if they sink or what but it does happen. I just disconnected it and got a replacement later.
08 OPA High Points Champion
glassdave is offline
Old 05-26-2009, 08:00 PM
The flote gets stuck down and sounds the horn, Just get a new one when you get time. I have tryd to clean them but it never seems to work after cleaning it. You still do need that bottle working right due to the oil dose go down after awhile and you do want to know about it when it dose go down.
Boat Tech is offline
Old 05-26-2009, 09:46 PM
noyzee's Avatar
ok, i just didnt want to drive the boat if there was a way the float would block the hole or something. its cheep to change, and im taking the boat out of the water after this weekend, so if i use it this weekend then replace it once i get it home it sounds like i should be good
noyzee is offline
Old 05-26-2009, 09:51 PM
noyzee's Avatar
thanks for the info guys.
noyzee is offline
glassdave's Avatar
yep just keep a closer eye on the level till you get the new one. .
Old 05-26-2009, 10:05 PM
noyzee's Avatar
yea, i will, seems i use very little threw the hole season last year i was only down a few onces. last year i blew my drive so i changed the fluid in the drive and to be safe i cleand the tank and put all new stuff in. but i have atleast 25-30 hours on it since till i had the issue. sounds like she just died from being 5 years old
noyzee is offline
