If it uses a gear drive, then the cam and distributor spin in the standard left hand direction. The only thing that spins backwards is the crank. You will need a timing set and a starter. The cam and distributor are the same as the left hand engine.
On the other hand, some reverse rotation engines turn everything backwards, or right hand. It all depends on which one you have.
Eddie
True, Custom EFI and Carb. engines from 500 to 1500 HP. Also specializing in outdrive upgrades and repair, custom rigging and fabrication, we can handle all of your performance boating needs. See our entire engine line at www.YoungPerformanceMarine.com Contact us at 615-216-7449 or youngperformance@comcast.net
