Quote Originally Posted by KNOT-RIGHT View Post
The higher the degree rake the more bow lift?
Ex. Gino had a set of 10 degree rake which I beleave the blades
lay flatter. This would give less bow lift then a 20 degree?
Exactly, more rake = more bow lift.
It is basically the angle of the trailing edge of the prop. The higher the rake the further the blade reaches back making the blades longer on the leading edge.. If I set my props down on the trailing edge tips, the back of the prop where the nut goes will be higher off of the surface the props are sitting on than a standard prop.
