If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Blower question
  1. #11
    My Boats:
    88 IMP 255
    Join Date
    Dec 2008
    Granite City IL
    Quote Originally Posted by blue thunder View Post
    You need to run less total timing so look for a tbolt v-6 module with only 14* total advance. You stock v-8 module will probably have 24* which puts your idle timing to low. Set the total at 30* and you will be close to good.
    When I did my upgrades one problem I missed was the pulley ratios. I needed to change the water pump pulley to a different size to match the new v-groove/rib combo blower pulley. I kept thowing belts and replaced everything on the front of the engine before it dawned on me the problem.
    Thanks for the suggestion. the guy I got the blower from was having problems tossing the belt due to pulley alignment and he had to have the crankshaft spacer turned down just a bit. I am hoping I get lucky and have good belt alignment from the get go ( lol what are those chances!)
    I appreciate all the advice, I dont know alot about the thunderbolt so that helps out a ton!
  2. #12
    Registered blue thunder's Avatar
    My Boats:
    330 Carver 30' Scarab Panther 17' ProV Lund
    Join Date
    Nov 2001
    I wasn't throwing the blower pulley, it was the circulating pump, alternator and power steering belts that were the problem. Good luck with the install. I gained nearly 10mph with the addition of my 177s.
  3. #13
    Registered PatriYacht's Avatar
    My Boats:
    94 43SC Black Thunder
    Join Date
    Jul 2002
    Stainless Marine makes a thermostat housing for use with the 177 blower. Like everything Stainless makes, it's beautiful and ex$pensive.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
