-   -   Removing permanent marker from vinyl? (https://www.offshoreonly.com/forums/general-boating-discussion/211896-removing-permanent-marker-vinyl.html)
RebarBox 06-29-2009 09:52 AM
Thanks for the suggestions guys.
VtSteve 06-29-2009 10:42 AM
Not sure on vinyl, but I do know that Coppertone Sport Sunblock works well. I found this sometime ago on an Internet search. Isopropyl alcohol can also work, but tends to be harsher. Just make sure you pay attention and test it out, meaning spray a little, wipe off. It can make one spot seem cleaner than the rest.
Griff 07-02-2009 01:21 AM
Acetone on a Q Tip. Use it as sparingly as possible since the acetone will take the finish off the vinyl.
