If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Like Tree1Likes
Thread: Sensor Alarm - 2004 6.2 liter Bravo
  1. #11
    Join Date
    Jul 2009
    Napa was able to to cross the part the way, it is the same part used on a 2003 Lincoln LS with the 3.0 dohc motor. Hope this helps
  2. #12
    Registered Lauderdaleboats's Avatar
    My Boats:
    Bandit Boats
    Join Date
    May 2005
    Yes, funny huh. It's a Ford part.
  3. #13
    My Boats:
    1990 Mirage 257 , twin 6.2 MX
    Join Date
    May 2004
    Vancouver B.C Canada
    Tried to post on this topic and it dissappeared as I clicked on 'submit reply' . Just as frustraiting as the problem with the IAC , pun intended.
    My engines have under 200 hrs , and the port side IAC got stuck. No #code but the SmartCraft gauge gave warning to throttle back , because of high fuel level. Limped back on one engine . Pulled the IAC to find the pintle stuck . Couldn't move the shaft with a pair of pliers either. So I tapped on the solenoid cylinder a few times and got it unstuck. However I didn't trust it and ordered a new one form Merc, at a cost of $98 cdn , overnight shipping.I opened up the unit to show you all what's inside, and you'll find there's no way to get contamination inside the coil to stop the plunger, because of the protecting membrane. It was sqeaky clean inside so it's definitely a notorious part. I have a 96 Mustang with over 140K miles and the IAC works perfect , albeit it's a slightly different unit. Merc had to pick a model that gives us trouble , go figure.
    here's the picture of said unit.
  4. #14
    My Boats:
    2003 Monterey 298 SC
    Join Date
    Nov 2008
    Fort Worth, TX
    I had my mechanic out yesterday for the 2 beeps every 2 min alarm on my 03' 350 MAG MPI's. Turns out the IAC was starting to go bad, but still working. Was told that when the engine throws this code, the engine went to 90% available power. If it goes completely out, the engine wont idle smoothly or run well. He also said dont put car parts in it as he or other Mercury mechanics wont be able to work on it in the future due to non-recommended parts. Guess I will pay Mercury’s price for the right part.
    MASOMAN likes this.
  5. #15
    SeaRay Sundancer Gold Member tblrklakemo's Avatar
    My Boats:
    In the Slow Lane
    Join Date
    Nov 2005
    SW Missouri
    wow...this is handy and ironic. Last weekend I was idling for an extended period waiting for a buddy to get his anchor set. Ive got an 02' 6.2 Anyways I start getting a single beep every minute or two.......I didnt clock the time between beeps. Never came back when I was running or idling later. By a previous post it should be low drive lube. It isnt low so it must be a faulty drive lube sensor?
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
