Any New 575sc Mercury motors out there?? >
Old 06-27-2009, 06:33 PM
Rob
Strip Poker 388's Avatar
Question Any New 575sc Mercury motors out there??
I Have a buddy wanting a New one, he might take a good rebuilt one or new long block, He wants to be running by the 4th Maybe?
Its a 2004 with 175hours.
Strip Poker 388 is offline
Old 06-27-2009, 10:03 PM
Ptufaro's Avatar
I have a 525 if he's interested he can pick it up on Monday Morning. 14500
504-343-7383
Ptufaro is offline
Old 06-28-2009, 12:31 AM
Rob
504-343-7383
He's wanting the 575 at least,Thanks for the offer.
Old 06-28-2009, 08:01 AM
There was one for sale in the swap shop. I believe it was in Wisconsin. Dont know if its still available but its worth a shot. I would post the link if I knew how. Sorry.
obsessed1 is offline
Old 06-28-2009, 09:44 AM
JCPERF's Avatar
What about a 525 that makes 575?
JCPERF is offline
Old 06-28-2009, 09:52 AM
Michigan Mad Man
Racer
How about a 525 that makes 630hp
TylerCrockett is offline
Old 06-28-2009, 12:46 PM
JC Performance Engines
Stormrider's Avatar
Check w/ Mel Riggs. He may have some around.
Stormrider is offline
Old 06-28-2009, 12:53 PM
Registered User
BAJA WILL's Avatar
BAJA WILL is offline
Old 07-06-2009, 03:05 PM
Rob
Well I couldn't find any 575's and he had to be running for the 4th,he had a local jake leg mechanic pull the top end down,found a intake leaking water in the motor. The Merc intake was corroded thru in the rear water outlet,but the intake doesn't have that provision,I guess when flushing the motor it doesent flush this area,dead end? Well he was running on the 4th for about 2hours ,no shake down run or anything It burned 4 quarts one way,his mechanic said that it was a PVC valve that was stuck the reason it burning oil.They put more oil in and took off for home,half way,boom.He said that the one motor he had to run the throttles cocked, being the sick motor was at 3-4psi boost trying to keep up with un hurt motor, (thats prob what killed it) they said it started loosing power ,spit and popped and died, wouldn't crank back up.
I'm guessing hole in a piston,I wouldn't think a leaking intake gasket would suck out 4 quarts in a hour?
What do yawl think?
Rob
Old 07-06-2009, 03:49 PM
Neither of mine used any oil, and I've heard
other owners of 575's say the same thing.
Did the mechanic take out or leave out the baffle tray
that goes uderneath the intake ?
Going thru 4 qts in that amount of time sounds crazy.
JaayTeee is offline
