Stock 500EFI dyno sheet
Old 07-24-2009, 12:01 PM
onesickpantera's Avatar
Default Stock 500EFI dyno sheet
Anyone have a dyno sheet they can post or email of a STOCK 500EFI? I tried to search for one but the search function picks up on way too much.
onesickpantera is offline
Old 07-25-2009, 08:56 AM
you want it with the gil headers or cmi headers ?
yahoo is offline
Old 07-25-2009, 09:00 AM
Either or both will work. But I thought the EFI only came with CMIs?
Old 07-25-2009, 12:55 PM
JCPERF's Avatar
They make about 520 hp and 570 ft lbs
JCPERF is offline
Old 07-26-2009, 01:30 PM
Thanks guys I'm looking for an actual sheet so I can see the numbers from 3000 rpm up.
Old 07-26-2009, 11:48 PM
Disclaimer: this is not my engine, not my data, rather it is info someone posted as a legitimate stock 500HP dyno test. With that said, it looks correct.
The 470hp is at the prop and should cover an engine at the low end of the production variability.
bsfc fc torque BMEP
rpm hp lb/hp*hr gal/hr ft-lbs psi
3300 344 0.49 28.1 547 164
3400 354 0.47 27.7 547 164
3500 364 0.46 27.9 546 164
3600 374 0.45 28.1 546 164
3700 384 0.45 28.8 545 164
3800 394 0.44 28.9 545 164
3900 405 0.43 29.0 545 164
4000 416 0.43 29.8 546 164
4100 426 0.42 29.8 546 164
4200 437 0.42 30.6 546 164
4300 447 0.42 31.3 546 164
4400 457 0.42 32.0 545 164
4500 468 0.42 32.8 546 164
4600 478 0.42 33.5 546 164
4700 487 0.42 34.1 544 163
4800 495 0.43 35.5 542 163
4900 503 0.43 36.0 539 162
5000 510 0.43 36.6 536 161
5100 517 0.43 37.1 532 160
5200 523 0.44 38.4 528 159
5300 527 0.44 38.6 522 157
5400 530 0.45 39.8 515 155
ECeptor is offline
Old 07-26-2009, 11:52 PM
Cutting and pasting from Excel was a little messy. Here are the columns
1) rpm
2) hp
3) bsfc in lb/hp-hr
4) fuel consumption in gal/hr
5) torque in ft-lbs
6) BMEP in psi
If you want the Excel file, post your email and I'll send it to you.
ECeptor is offline
Old 07-27-2009, 08:50 AM
Thanks ECeptor that's what I was looking for.
Old 07-27-2009, 09:06 AM
I have one that compares EFI and Carb gill and cmi headers.
I will email it to you if you post your email or send it to me.
yahoo is offline
Old 07-27-2009, 09:13 AM
Received 1,325 Likes on 739 Posts
I would like to see that.
[email protected]
Wildman_grafix is offline
