BIG Time motor problem ...any ideas ?????
#61
Geronimo36
Big Chief stuff usually run around 30 degrees.If it is 14 degree or less Big Chief stuff they like 28 degrees timing.As far as the jets thats way to small.Fuel pressure should be at 7.5 to 8 lbs.For the hell of check your fuel tanks for ****,Skaters have a tendency to have fuel tank issues with Ethanol.
PS, Jeff made Richie do the steady state runs cause he wanted to beat em up a little!!
#62
[QUOTE=offshoresteve;2920436]Man that Sux Sh*t Bill . All that paint work and prep you did over the winter to have your boating season cut short by Sh*t work done by someone you trusted and paid alot of $$.
U dont have to say that twice Steve , the killer is with the old motors we'd still be running in 2009 that leaked down good but the smoke up my azz sounded great .Bigger power,reliability,but motors were to be built for 93 octane and Methanol as a added bonus to help with egts was not to ever intended to run methanol from 4 lbs of boost to band aide a too high compression motor that was always known going to run 15 - 16 lbs of boost
#63
Beak botr
Turbine Time
Rerig with a pair of turbines and small diesel maneuvering engines. Diesels set up to power small props mounted above bottom of boat (only usefull with hull in the water), on plane they are totally out of the water. Diesels to also provide power to cold and hot start turbines. If I hit the lottery this is how I would set up my dream boat. Would only want 5 to 10 mph out of the diesels so perhaps 25hp each, enough to cool and hot start the turbines.
#64
They dyno'd these motors right?
I'm starting to think the same thing Bro motor came back at 34 degrees timing,never recieved the Vid or pics of the dyno pulls,1 blower was siliconed and torqued at 16+ lbs the other no silicone and only hand tight I will dig up the 34 degree timing email and post it
I worked at a machine shop about 15 years ago (they still build all my stuff) and it didn't matter if you had a million dollars or 2k in parts, everything got checked and double checked before it left the shop. The basic same group of guys are still there today and still produce some very nice work.... out of the same shop for the last 30 years.
#66
I am still down too.. And it isnt on my end either.. But it is coming together. I am just anxious too.. Good Luck and If there is something I could do to help.. Don't hesitate to ask!!!
#67
Complete bummer dude. Im shocked at this story.
No dyno picts, no trace of timing changes v power, or Air fuel mix, power from a dyno sheet= no beleiva he did it.
The guy that told you 200 hours couldn't have used this combo before.
As another guy stated- Never seen Big chief heads go for more that 50 hours without a valve train redo. Big Chief = big pain in the A$$.
Very few guys that actually have to warranty stuff use Big chiefs.
I can hear the other side now......
He'll blame your fuel delivery system as not delivering enough pressure and claim you used cheap gas.
I think Gellner, Eddie, Ateco, or Teague would be a good way to just cut your losses at this stage. It would have been cheaper to spend more at Sterling.
Good luck with this one dude. Were all Cringing.
UD
UD
#68
I here ya big Daddy... You almost need to get them built in the early fall run them in FL or South in the warm then get ready for summer in the spring to make sure there is no problems.. Problem is you get your chit when they get around to it then you got problems in the height of the season.. THEN WHAT!!
#69
The legend himself, Keith Eickert, is not all that far from you in Easton, IL. at Lightning Performance Group.
http://www.kustomengines.net/
You cannot beat Eddie Young though for the ultimate in customer service and final dial-in.
#70
UD
UD
