Floating boat lift - Am I nuts? >
Old 08-04-2009, 01:42 PM
yss
Originally Posted by HTRDLNCN
considering the cost of a lift for a 33ft boat why not just spend a little more and get the area where the lift will go dredged out? Then you could use any kind of floating lift you want.
My neighbor and I have done this twice in the past 10+ years but the lake is fed by the fox river and soot just fills it back in.
yss is offline
Old 08-04-2009, 01:45 PM
yss
Originally Posted by Strip Poker 388
just hook the boat up to the slip and blow out the mud
Done this too Strip!
yss is offline
Old 08-04-2009, 01:53 PM
Brian - looks like you're getting lots of suggestions here. For the coin your talking about, I would think that dredging would be a solution then install one of the more conventional lifts.
What has some of the others on the lake done?
Holy Smokes is offline
Old 08-04-2009, 02:59 PM
you may just need to keep doing it every 5 years then,
even with a low working lift I wouldnt want all that crap stirred up when you start your boat up if its that close.
HTRDLNCN is offline
Old 08-04-2009, 03:28 PM
yss i don't know you but i think you hsve to look for another place on the water
thedonz is offline
Old 08-04-2009, 08:03 PM
My Airdock lifts my 32' Sunsation without a problem (6200 lbs dry weight) in pretty shallow water. Give them a call. Very cost effective compared to some other options.
Ryan8886 is offline
Old 08-04-2009, 09:02 PM
YSS, look into two post elevator lifts. Close enough to land where ice flow would be slim once lake levels drop for winter.
AO31 is offline
Old 08-04-2009, 09:40 PM
Hydro hoist or some of the other brands built at LOTO have shallow water setups with smaller tanks. Just a thought.
redbud35 is offline
Old 08-04-2009, 11:24 PM
I had mine dregded for $500 bucks ,Hydrohoist with a 30ft cat ,Happy days
olmo40 is offline
Old 08-05-2009, 06:44 AM
Charter Member #232
Audiofn's Avatar
This is the nicest unit I have seen for this aplication.
http://www.sunstreamcorp.com/floatlift.htm
Put your best foot forward!
Audiofn is offline
