-   -   Any Dodge truck owners with Rear end problems? (https://www.offshoreonly.com/forums/general-boating-discussion/21490-any-dodge-truck-owners-rear-end-problems.html)
Cutwater 04-03-2002 02:13 PM
Flinbrain.... Thanks for the info. I'll have it checked out right away, checking for metal in the oil. Mine only made a slight noise once that I have noticed, kinda like the sound you hear when you back over a bayliner ............ just a little crunch & grind. No noise since then.
Niuhi .... Mine is a 96' 2500. Not as heavy as yours, but heavier than a 1500.
Roger:cool:
Cattitude 04-03-2002 02:41 PM
Dodge rears
I'm on my third (and last for a while) Dodge.
95 5.2 dakota, carrier brgs at about 36K under warranty, did not feel bad, towed a lot with it and it was an 8.25 rear axle- traded at 40k
98 durango, 5.2, towed with that too, never any trouble, 9.5" rear like the 1/2 ton pickups, traded at 40k, no trouble
2001 2500 with hopped up cummins and 11.5" Dana 80, tow often (Pure tow rig now, bought a grocery getter), 55k, runs strong, many trips grossing 20k.
The 9.5" generally has a good rep, you can get a "bad" bearing in any axle.
If you can handle the noise and smell, diesel's the only way to tow- get your $upgrade money back on resale.
mxz800 04-03-2002 03:47 PM
my brother had one go out on his 1500 4x4 at 45k mech at dealer said they have been seeing this problem with a lot of 1500 series 4x4s.
Sean 04-03-2002 04:12 PM
I've got a 1999 Jeep Grand Cherokee(Chrysler Product) and the rear differential was just replaced after 38,000 miles!!! It was making that loud humming noise like I had a set of Super Swampers all the way around, so I brought it to the dealer.
The front brakes were replaced at 20,000 miles, rear brakes replaced at 38,000 miles and the rear diff at 38,000. I WILL NEVER buy another Chrylser product...not olny because they SUCK, but the dealer that I have been using SUCKS too. My last routine service(38,000 miles) cost me 1200 bucks!!!
Don't ever bring your vehicle to Bayside Jeep in Bayside Queens, NY!
Interceptor 04-03-2002 04:15 PM
Had pinion bearing failure at 79K on a 1996 Ram 1500. It looked like one roller bearing had a small piece break free and score the remaining roller bearings. sounded bad but never completely failed.
Hauling Trash 04-03-2002 04:39 PM
I got a 1500 4+4 ex-cab 1998 with 40,000
i love it no problem`s here
mike
29Fever 04-03-2002 04:47 PM
Buddy of mine dropped his rear on a '98 1500, but it did have 90k on it. Won't catch me dead in Chrysler product.
CheckmateF1 04-03-2002 04:59 PM
Had one. 95 Ram 1500 4x4, 5.9l v8. Rear end was toast at about 80k miles. Needed a complete rebuild. Trans went south at 70k, had it fixed then the torque converter actually exploded and left us stranded for 5 hours with the boat in tow. Took me about 5 yrs to figure out a good combination of pads and rotors that would stop well and last.
Other than that we loved the truck. But towing 5500lbs all summer took it's toll. Now we have a 2000 F-350 V-10 and will probably never buy another Dodge truck.:mad:
Eric
Budman 04-03-2002 05:15 PM
Pinion bearing or backlash?
I have a '92 Dakota with the 9 inch rear end, and it has been making the humming noise for several years now. The noise only happens with light throttle - goes away when it coasts or under heavy load. Also gets louder on a right-hand turn. Right now it has 152000 miles on it. I pulled the axles and carrier out last year and inspected everything because I thought it was an axle or carrier bearing. Everything looked OK, not a lot of metal in the lube. Now I'm suspicious that there is excessive backlash between the ring and pinion. Might pull the carrier out this fall and try to re-shim. I replaced all u-joints and driveshaft carrier bearing last year, along with transmission mount.
I had problems with the limited slip clutches popping until I ran the Mopar HD lube. No problems since then, all this after replacing lube several times (with posi additives) because of this problem.
Transmission has occasionally made a loud buzzing sound in reverse since I bought it in '96. Windshield wipers started making a grinding sound like the "wa-wa" guitar in an old Cream song for the last five years, but they still work. I keep waiting for this thing to crap out and fall apart, but it just keeps going! I guess I can't complain - haven't been stranded yet, and it's been through hell and back several times. Even did some "ditch jumping" in it with the boat in tow! :eek:
I'll probably just drive it till it drops, then get something newer. If it makes noise, just turn up the radio! :D
MitchStellin 04-03-2002 07:26 PM
Flyinbrian, thanks for the tip. I had that knock for many miles. I am at 180,000 with a 96 1500 ext cab. One tranny at 115,000. No rear end (3.92). This truck has towed 10,000lbs 7 hours a dozen times. Air bags on the rear help a lot. No other problems. I have driven them all and I have never kept a truck this long. The best I have ever had.:D
