Know where I can find a cheap ecu for 5.7 EFI
I have an ECU off a 454 mag mpi. If its the same part, AZ speed and Marine could reflash it for 5.7 use. Off a 96 454 mag efi. Had 50 hrs before replaced it with a trick ecu from AZ speed and marine after installing blower. It is a merc. check sum # 9402. Delco model number 16234539. These babys are $5-600 new. I'll take $200.
Thanks for the response! I don't think that will work. The part number on his ECU is different thatn the one you have. I have no idea what the difference is or even if there is a difference.
Anyone know?
Believe it or not, the ECU for his engine lists at $1200.00 bucks!
Anyone know?
Charter Member #139 /Moderator/Platinum Member
wow original post is from 2002 and thread starter appears not to be a member anymore
Kept the Bullet and the condo and joined the cig 20 restoration club.
