Opinoion on 35 Lightning Staggard
I would like to ask anyone with experience on 35 Lightning's with staggard engines for any opinions, concerns problems etc... that they may have encountered. I am looking at a 35 with the 496's and bravo xr SSM's. The boat has Hering 32 6blades on it and runs about 83 with 4 and full tanks. Any info on this type of setup would be appreciated.
32p sixblades? running 83.....
i think way to much prop |
Originally Posted by dreamer
(Post 2941358)
i think way to much prop BTW Capt a Bravo XR is not a Super Speed Master drive. |
The boat should run alot faster than 83.
Originally Posted by Catmando
(Post 2941359)
BTW Capt a Bravo XR is not a Super Speed Master drive. . |
Originally Posted by 2112
(Post 2941363)
Maybe he meant shorty sportmaster.
(Post 2941358)
Originally Posted by CaptJohnT
(Post 2941339)
The numbers do not add up. 1.5 gears/ 32pitch prop/ 10% slip (assume) / 83 mph/ = 4565rpm's ?????? (RBBI prop calculator) Something isn't right with the math. Darrell. Darrell. |
Originally Posted by DMOORE
(Post 2941385)
1.5 gears/ 32pitch prop/ 10% slip (assume) / 83 mph/ = 4565rpm's ?????? (RBBI prop calculator) Something isn't right with the math. Darrell. Darrell. It turns about 5000-5100 with the above mentioned load. The props do not have any visible markings from the outside so I am going on what Fountain said they put on it. I read in a post on this forum that the first staggard 35 in 07 went 90+?? |
