Who's running a #6 in a single engine application
#141
I may be wrong but arent the clutch shafts the same in the "bravo" type drives???
My drives do not have a fixed x dimention.
15 inches is the WMD
10.5 is the WSD
4.5 is the WDP
We never line up the crankshaft to the input of the drive so it really doesn't matter what they are. When I went to put a WMD and a WSD on a small boat I had the prop where I wanted it and the gimbal was above the transom. So finally I designed a very short X dimention drive, The WDP.
When we replace a #6 we use a 5.5 inch offset box to get to the 18 15/16 x dim.
When I see a 19 t spline propshaft I do not think of a drive you can hammer.
pat W
10.5 is the WSD
4.5 is the WDP
pat W
#142
Chris
John is also correct on the stats for the single engine cats.
Chris
#143
Talked to IMCO today, the only failers that they have had are shifting @ higher @ RPM, above 800 other than that they told me knock on wood no problems, I can use my MMW lower on the drive I will just have to go with a lager upper shaft and it will all mate up to the upper, this is really looking like the rout that I am going to take. Don't get me wrong, I love the MMW drive and it has really heldup better than I exspected but I am just looking for more reliablity out of a drive, so if anyone is interested I will be putting the drive up for sale on the Classifieds, FYI every thing in the upper is brand new, all new gears, clutch shaft and all bearings, and races, they also upgraded the billet top cap with larger studs and nuts to ad even more rigidity and reliablity...a new drive is 17,000 pluss dollars top and bottom I am working up a price but the drive will be back Friday I will take pics and post on the classifieds
#144
Chris
Smart move in my opinion.
You can re-coup some of the cost of the SCX upper by the sale of your MMW upper.
Are you saying that the MMW lower will mate up to the SCX upper by using IMCO's conversion shaft?
If so... that is great news!
Chris
Chris
#145
Not really worried about the cost, just looking for longevity, and peice of mind
#146
Yep, The boat loves the MMW lower, I ran an bmax with the short lower and it spun out @ 60...running the MMW lower, lets just say @ 80 in a u-turn I chickend out I figured 80 was fast enough for testing, plus I don't think I could have held on pulling any more g's
Something else reading your post,this may even be a non-issue since you are going to a different drive but for the guys stuck running bravo drives 75 hours is waay to long to go between tear downs and inspections on a bravo drive behind big power. I change the oil in mine every 10 hours and tear it down and inspect everything at least every 30-40 hours or less if I start finding metal in my oil. In 9 years of running various blower motors from 650 hp,then 750 hp then 950 hp and now 1050 hp I have never blew the teeth off a upper gear or destroyed a case. I have found bearings just starting to fail,clutch shafts that were fractured,lower gears that were on the verge of total failure etc. Many of these problems I found would have led to total destruction of the upper or lower IF I hadn't caught them,fyi,Smitty
#147
I would still get away from the bravo style lower,I run 1050 hp 1000 plus ft lbs of tq and I never get 75 hours out of lower bravo gears even with the best preperation, cryo finish etc.
#148
#149
#150
