If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. #11
    Charter Member # 55 Charter Member Griff's Avatar
    My Boats:
    ..........32........... Active Thunder
    Join Date
    Oct 2000
    Quote Originally Posted by carcrash View Post
    Also, the torque from the prop will certainly cause the boat to roll. And the higher the X dimension (the higher the drive), or the more the drive is trimmed up, the more you will see the effect! Power on it will both roll and want to turn one way. Power off, the other.
    I would disagree with that. In my experience, trimming up and adding speed will reduce the torque roll and lean. The prop does not dig into the water as hard and is spinning closer to the surface. Of the single engine boats, I've owned, this has always been the case.
  2. #12
    Platinum Member Platinum Member Rick G's Avatar
    My Boats:
    1985 38 ft Cigarette Flat Deck, 1991 Donzi Sweet Sixteen, 1972 Magnum 27 Sport
    Join Date
    Oct 2000
    Toronto Canada
    It sounds like the drive may not be square to the transom. It may that if the drive is not straight it may cause the boat to lean as the drive have a tendancy to want to square itself at speed. Does the boat lean at slower speeds? this might be a tell tale.
    Rick G.
  3. #13
    Registered HotSpare's Avatar
    My Boats:
    22 Donzi
    Join Date
    Nov 2002
    Dallas, Tx.
    Boat is leaning to port, with port tab down 12in is bad math... Something wrong in tab land I would suspect ..... Without tab indicators would be impossible to indicate a floating tab .... Only other thing would be disturbed water for the tab to fly, not able to get a solid bite on the water, caused by other mods youve done ........ bottom line, port tab is not getting a bite .......
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
